  • Replies 41
A starion turbo was my First car, i bought it almost 6 years ago.
To this date, I cant stress what a great car it was, and what a great car they are. It rarely gave me trouble and I thrashed the hell outta it, I was a year 10 student at the time so I couldnt afford anything else. Imports were few and far between and extremely expensive back then. I had it for two years!!
Ive had quite a few imports, and even still, i have to rate Starions as one of my favourite.
The sad thing is, 90 percent of starions left, are all neglected, bodged up and tired. In melbourne ive noticed this anyways.
They have so much to offer that most cars built in the 80s hadnt heard of - and there rare.
Everyone these days are going the skyline, silvia, R31, Corolla for slide cars - what about something a bit left wing! Dont be put off because you seen a hack, theres many types of the abovementioned cars that ive seen that are in similar condition. The single cam motors are strong, the turbos are good if they are looked after, good oil, a seal kit etc.
In a few years I will buy a widebody Starion to Restore from the ground up, they are the Forgotten Classic Japanese sports car.
It puts a smile on my face every time I see one out and Im glad that there are people out there that value the old Japanese classics.
Well said, starionturbo :) BTW, most widebodies from Japan are in very good original condition as they are rare over there (just over 850 made). Also, since only pre-1989 cars can be imported, there are only about 300 of them that were made in 1988.
Don't give up so easily Dean, there are a few good examples around and you may have to look at a few cars before you find the right one, just like you would with any other car. Like any car of its vintage, it will have its faults and problems - the aim is to find one that has the least problems and the right specs to suit your budget and objectives.
keep an eye on the for sale section of austarion.com and I am sure you will find one that suits your needs.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
