hi everyone had a look around forums need to verify a few things, my r34 has the triple gauge set up, i want to replace the boost gauge, will be getting a 52mm guage which should fit. my question is how do u remove cluster i read somewhere cant find it now u pry open air vents which are clipped in, with screwdriver is that right?
There are screws holding the cluster & clips? also can i just remove the old gauge and replace it and use existing wires? is the stock guage mechanical or electronic? thanks in advance...... any pics would be great.....
Edited by rgr34
https://www.sau.com.au/forums/topic/176234-replacing-factory-boost-gauge-r34/
I've had the guages replaced.
U cannot just change the one guage as they are actually 1 piece 3 guage setup.
the 52 mm gauge will fit inside a window of the gauge pod holder, but a custom fitting bracket will be needed for the 3 guages.
Try a search & you'll find a few threads regarding this topic
Ă—
Ă—
