Hi All,
R33-r34 Turbo, differences??
I have used the search but i cant find anything
Can someone please help?
maybe specs n stuff of the r33 from someone and the specs about the r34 from someone else..
then i can compare..
thanks pplz
Lighty01
PS. Info just about the turbo only
Edited by lighty01
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/
sorry matey, but that's incorrect.
r33 turbo = ball bearing.
The sI turbos had a metal compressor wheel.
SII turbos have a bakelite compressor wheel for faster spool
both have ceramic turbines - the limiting factor. Once boost is increased too much, the rear wheel pops.
some r34s had the same turbos as r33s.
The rest have the same turbo but a larger exhaust housing like the vg30 turbo.
I have a large housing avaialble if you need it.
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3225302
  • 3 months later...
If the R34 and VG30 have the same exhaust housing does this mean they will perform much the same?
I have a VG30 on my RB20DET and wanted to go to something less laggy. I am ready to buy a R34GTt turbo, though it is clearly not worth my while if there is no difference between the two.
Your thoughts?
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457805
I just bought an R33 Series 2 turbo for my RB20, I was after a 34 one but they are too hard to find and overpriced. But if there's f*ckall diff then i'm glad i've gone the 33 S2. Would putting the larger 34 housing on it be a bad idea and make it more laggy on the RB20?
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457960
KeyMaker,
Are you saying that a R34 GTt turbo would be more laggy than a VG30 turbo or more laggy than an R33 GTSt turbo?
The benefit of the R34 turbo over the R33 is not that it is more power, rather, that it is newer.
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457979
Yes its based on the exhaust housing....primarily.
R34 turbo should be less laggy than a VG30 turbo due to the use of a nylon/plastic impeller. I'm not sure on the specs of a VG30 turbo or what impeller it uses so i'm assuming its a steel impeller. So therefore the R34 turbo has a lighter rotational mass to turn = less lag.
But the R34 turbo shares the same exhaust housing as the VG30 turbo.
If I were you, I'd get a R33 S2 Turbo if you want to reduce lag & and you'll still get the same power, as the compressor housing on the 33 is the same as a 34 turbo and you won't be able to run any more boost than a 34 turbo.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3458004
Just on topic..
R33 turbo is laggier and will have less responce than a R34 series one turbo .. R34 series 1 turbo spools much quicker and with the right mods can be full boost a 3g and less.
R34 turbo series 2, is bigger and can run a higher boost level, still spoools quick but not as fast as a series1 .. Ideal for a high flow.
I only know this because ill be doing exactly that for my 34
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3458191
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
