Hi All,
R33-r34 Turbo, differences??
I have used the search but i cant find anything
Can someone please help?
maybe specs n stuff of the r33 from someone and the specs about the r34 from someone else..
then i can compare..
thanks pplz
Lighty01
PS. Info just about the turbo only
Edited by lighty01
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/
sorry matey, but that's incorrect.
r33 turbo = ball bearing.
The sI turbos had a metal compressor wheel.
SII turbos have a bakelite compressor wheel for faster spool
both have ceramic turbines - the limiting factor. Once boost is increased too much, the rear wheel pops.
some r34s had the same turbos as r33s.
The rest have the same turbo but a larger exhaust housing like the vg30 turbo.
I have a large housing avaialble if you need it.
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3225302
  • 3 months later...
If the R34 and VG30 have the same exhaust housing does this mean they will perform much the same?
I have a VG30 on my RB20DET and wanted to go to something less laggy. I am ready to buy a R34GTt turbo, though it is clearly not worth my while if there is no difference between the two.
Your thoughts?
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457805
I just bought an R33 Series 2 turbo for my RB20, I was after a 34 one but they are too hard to find and overpriced. But if there's f*ckall diff then i'm glad i've gone the 33 S2. Would putting the larger 34 housing on it be a bad idea and make it more laggy on the RB20?
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457960
KeyMaker,
Are you saying that a R34 GTt turbo would be more laggy than a VG30 turbo or more laggy than an R33 GTSt turbo?
The benefit of the R34 turbo over the R33 is not that it is more power, rather, that it is newer.
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3457979
Yes its based on the exhaust housing....primarily.
R34 turbo should be less laggy than a VG30 turbo due to the use of a nylon/plastic impeller. I'm not sure on the specs of a VG30 turbo or what impeller it uses so i'm assuming its a steel impeller. So therefore the R34 turbo has a lighter rotational mass to turn = less lag.
But the R34 turbo shares the same exhaust housing as the VG30 turbo.
If I were you, I'd get a R33 S2 Turbo if you want to reduce lag & and you'll still get the same power, as the compressor housing on the 33 is the same as a 34 turbo and you won't be able to run any more boost than a 34 turbo.
Edited by KeyMaker
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3458004
Just on topic..
R33 turbo is laggier and will have less responce than a R34 series one turbo .. R34 series 1 turbo spools much quicker and with the right mods can be full boost a 3g and less.
R34 turbo series 2, is bigger and can run a higher boost level, still spoools quick but not as fast as a series1 .. Ideal for a high flow.
I only know this because ill be doing exactly that for my 34
https://www.sau.com.au/forums/topic/176238-r33-r34-turbo/#findComment-3458191
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
