Wheels: R34 GTT Manual Coupe
Work: IT Officer
Music tastes: Pretty much anything but prefer electronic and acoustic these days
Hobbies: Cars, Computers Track days etc
Been on SAU since before I got my 34, but recently recommended to contribute by Manne. I run Octane Coalition on facebook, had monthly track days down at the RAC until it was recently wiped out.
Have a 2000 R34 Manual Turbo Coupe, has a load of handling mods and some basic bolt ons (zorst fmic high flow etc). Has 250hpatw being held back by the aging fuel pump and injectors. Looking to upgrade those and push for more next year.
  • Like 2
  • 5 months later...
Copyrighted since: 19 Feb 1992
I drive a: Black R34 GTT, AE71 PV, KE70, 1UZ FJ73 and the others aren't licensed..
I work as: A Diagnostic Tech at VW
Cruise/event attendance rate: Probably more than usual now since attending the SAUWA meet yesterday..
Music taste: not 92.9, 93.7 stuff.. I don't care if it's 'old skoooel'. I like most music that's usually found on triple J.
Hobbies: Cars. Pool, photography, training my dogs (yelling their names until the return to me).
Might be of use contacting me for: A fellow skyline to tag along on a meet/cruise. Mechanical questions (keep in mind I only purchased a skyline last year)
Thanks IMG_1486297886.980463.thumb.jpg.30c77bed
  • Like 4
Most of us talk in wasteland :) Jump in there :)
  • Like 2
  • 7 months later...
Hey guys haven't been on here for while but been a member of sau for some years now keen to get back into motorsport scene a bit more and get out and about . Still got my gtr although I hardly drive it anymore would like to get it out a bit more.
I'm also an auto elect with my own business if ya need anything give me a shout visit my fb business page
https://www.facebook.com/verrelliautoelectrical/
  • Like 3
  • 1 month later...
  • 2 months later...
Hey all just moved to Perth a couple of years ago. I just recently bought an r33GTR and keen to go on a few cruises and track days.
Not my first GTR as i used to own an 800+hp R32GTR. Cheers
  • Like 2
Welcome to the club!
  • Like 1
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
