Ermm
Ever since Ive had the car arrive from Japan, the steering has been very very heavy. @ all speeds. It's great for draging at WSID but shitty for windy roads and roundabouts!
Ive gotten used to it but it's pretty annoying now and then..
So what's causing this? (Ive had a search but nothing definiative with a solution.)
1. I think their is enough fluid in there. Not sure have to get it checked out.
2. The steering fluid box broken?
3. Speedo works.... pfc say the pump is working but I dont have the speed reading on the pfc (Only rpm, think the speed wire is cut at ecu wire loom)
4. Blocked lines?
5. Broken power steering?
Can anyone help?
Yes it's not just me other people say my steering is heavy, even Abobob said so! So must be heavy!
https://www.sau.com.au/forums/topic/176264-power-steering/
i would look at correcting this. you may find it magically solves your steering problem. also look in your power steering fluid resevoir and see if there is any fluid in there would be a good place to start.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225633
Hmm yea Ive been meaning to rewire the ecu. Been lazy for last xx months lol
In the resevor you are suppose to see fluid? Because I think I see some well according to that little guide under the resivor cap it says it's full... hmm will check this on Saturday when there is light.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225925
nope HIcas light is off... Ive only seen it go on when I had water in my coils and car was jerky.. So I dont think it's the hicas.
I do have power steering but just very stiff like my steering is on viagra or something :)
It may be the speed wire, as Duncan/Richard has said which makes sense ey. I'll have a look at rewiring it soon...
Hopefully this fixed means I can go drift around round abouts weeeeeee lol :)
I'll report back when Ive done the wiring fix!
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228524
So anyway didnt need to rewire the speed wire, it had one of those connectors..
Now my pfc controller tells me what speed im not going! Didnt happen before.. lawl.
Also checked the resivior and it's full.
Perhaps it maybe the steering line or something blocked in the lines. or maybe the pump is dieing?
go to the gym turd!!
LOL :P
Maybe i'm paranoid, but when I move the steering on Missturbos car and also drove Haysey's car awhile back and it is ALOT lighter than mine! Much like how the rolla steers.
Could it also be the tyres i'm running? larger tyres? But this shouldnt be the case.
dammit! :D:happy:
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228838
Stupid question..
I suppose you would notice the boiling temps by now..
But if your power steering belt the right size/tightented/not too tight?
Is there enough Power steering fluid?
Pump working?
All hoses connected?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3231394
  • 2 months later...
having the exact same issue but with the HICAS light on in my r32 GTST
Speedo not working - RPM working
steering is really tight at low speeds
getting it looked at soonish.
any idea how much it should be to get this fixed?? anybody ?? :P
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3359633
I got this fixed...
Problem was...
Power steering pump, the filter was being clogged and hence lower power steering pressure and also it was leaking. Got it reconditioned and car is like a brand new car, ive never driving it with such ease.
Also the soloniod at the steering rack was not grounded properly (not sure what this does but I assume it's the >100 speed to make the steering slightly heavy when at high speeds). Because I notice now that at low speeds steering is easy, then as I get on the hwy the steering is heavy abit to counter the light steering.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361387
I got this fixed...
Problem was...
how much did it cost? or did you just do it urself?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361430
any idea how much it should be to get this fixed?? anybody ?? :D
Your speedo cable is broken. get a new one and install it and it will fix all your issues.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3362014
I got this fixed...
Problem was...
+1 on how much...?
been meaning to get this fixed on my car too - i can see if leaking from the p/s components above the rubber sleave on the drivers side.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3363946
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
