All parts are for sale, although I have sold most of the major parts including the engine, gear box and diff, don’t hesitate to ask about any parts not listed below.
Will post items anywhere in Australia at buyers cost.
I am located in Townsville, Queensland. (4814)
Send me a PM with any questions, or I can be contacted on 0438737278.
Or email at [email protected]
• Front seat (Pair) - $150
• Another front passenger seat $70
• Rear seats - $80
• Dash surround - $100
• Both Door trims (switches not included) -$200
• Drivers side window control unit -$130
• Lower dash trim and side air vent - $60
• Centre consol surround - SOLD
• Middle consol - $70
• Battery hold down - SOLD
• Blitz SS Blow off valve and pipe (direct fit) - $200
• Complete standard fuel pump setup - SOLD
• C’s Short shifter - SOLD
• Complete dash with all vents -$200
• Stock intercooler setups x2 - #1 $50 (missing some pipes) - #2 $65 (all pipes)
• Space saver spare wheel - $50
• Steering wheel - $20
• Radiator surround - SOLD
• Wipers - $30
• Radiator over flow bottle - $40
• Washer bottle - $50
• A/C electric fan - $60
• Front chassis brackets - $15
• Clutch pedal (frame needs re-spot welding) $50
• 1x rear seatbelt - $20
• Rear side trims (Pair) - $70
• Dash cluster - $100
• Rear quarter window garnishes (Pair) -SOLD
• Boots trimmings - $50
• Boot carpet - $30
• Floor Carpet - $60
• Boot rubber seal - $40
• Inside door seals - $50
• Inside front floor trims - $30
• Outside window surrounds - $80
• Left hand side mirror (Black) - $110
• Lower front kick panels - $30
• Sun visors - SOLD
• Inside bonnet rubber - $20
• Revision mirror - $20
• Fuel flap (Black) - $30
• Interior lights - $30
• Front bumper brackets - $10
• Left hand upper side trim - $15
• Bonnet support - $15
• Rear self cover (No speaker covers) - $20
• Rear wing (Black) - $150
• Complete steering Column - $150
• Exhaust manifold wit heat shield - $50
• Power steering and Hicas lines - $30
• Hicas Pump - SOLD
• Intake to air box - SOLD
• Tail shaft - $150
• Gear box mount bracket - $40
• Exhaust mount and bracket - $10
• Chassis braces - $35
• Bonnet catch and bracket - $30
• Intake pipes to turbo - SOLD
• Horns - SOLD
• Wiper motor - $30
• Glove box - $70
• Foot pedal rest - $10
• Power steering reservoir and lines - $50
• Accelerator pedal - $10
• Brake pedal - $15
• Fuse box and car wiring loom - $80
• Fuel cap - $20
• Cross over intake pipe - $60
• Gear stick boot and surround bracket - SOLD
• Steering column surround trims x2 - $30
• Fan unit for heater-A/C - $80
• A/C Evaporator - $60
• Standard front pipe - $40
• Standard rear springs - $20
• Engine cross member - $120
More photo’s of parts are available upon request.
post-25231-1184224746_thumb.jpgpost-25231-1184211016_thumb.jpgpost-25231-1184210905_thumb.jpgpost-25231-1184210846_thumb.jpgpost-25231-1184210664_thumb.jpgpost-25231-1184210540_thumb.jpgpost-25231-1184210383_thumb.jpgpost-25231-1184210199_thumb.jpg
post-25231-1184222453_thumb.jpgpost-25231-1184222344_thumb.jpgpost-25231-1184211085_thumb.jpgpost-25231-1184211295_thumb.jpgpost-25231-1184211412_thumb.jpgpost-25231-1184211514_thumb.jpgpost-25231-1184211638_thumb.jpgpost-25231-1184211724_thumb.jpgpost-25231-1184211837_thumb.jpg
post-25231-1184211947_thumb.jpgpost-25231-1184212077_thumb.jpgpost-25231-1184212165_thumb.jpgpost-25231-1184212293_thumb.jpgpost-25231-1184212380_thumb.jpgpost-25231-1184212628_thumb.jpgpost-25231-1184212697_thumb.jpgpost-25231-1184212829_thumb.jpgpost-25231-1184213007_thumb.jpgpost-25231-1184213260_thumb.jpgpost-25231-1184213408_thumb.jpgpost-25231-1184214178_thumb.jpgpost-25231-1184214627_thumb.jpgpost-25231-1184215163_thumb.jpgpost-25231-1184215332_thumb.jpgpost-25231-1184215607_thumb.jpgpost-25231-1184217525_thumb.jpgpost-25231-1184217610_thumb.jpgpost-25231-1184217753_thumb.jpgpost-25231-1184218440_thumb.jpgpost-25231-1184219077_thumb.jpgpost-25231-1184219222_thumb.jpgpost-25231-1184219764_thumb.jpgpost-25231-1184220450_thumb.jpgpost-25231-1184220612_thumb.jpgpost-25231-1184220852_thumb.jpgpost-25231-1184221670_thumb.jpgpost-25231-1184221779_thumb.jpg
attachment=108136:Middlle_Consol__70.JPG]post-25231-1184222808_thumb.jpgpost-25231-1184222916_thumb.jpg post-25231-1184286353_thumb.jpg post-25231-1184223051_thumb.jpgpost-25231-1184223119_thumb.jpgpost-25231-1184223234_thumb.jpgpost-25231-1184223340_thumb.jpgpost-25231-1184223455_thumb.jpg
post-25231-1184223554_thumb.jpgpost-25231-1184223855_thumb.jpgpost-25231-1184223947_thumb.jpgpost-25231-1184224044_thumb.jpgpost-25231-1184224164_thumb.jpgpost-25231-1184224255_thumb.jpgpost-25231-1184224391_thumb.jpgpost-25231-1184224522_thumb.jpgpost-25231-1184224645_thumb.jpgpost-25231-1184224825_thumb.jpgpost-25231-1184225609_thumb.jpg post-25231-1184225475_thumb.jpgpost-25231-1184224942_thumb.jpgpost-25231-1184225045_thumb.jpgpost-25231-1184225143_thumb.jpgpost-25231-1184225350_thumb.jpgpost-25231-1184225240_thumb.jpgpost-25231-1184225737_thumb.jpgpost-25231-1184225820_thumb.jpgpost-25231-1184225938_thumb.jpgpost-25231-1184226041_thumb.jpgpost-25231-1184226138_thumb.jpg
Edited by trezy85
  • Replies 244
Posted Images
how long did it take you to upload those pics :) good luck with the sale
Yea it took a while, still cant get them to sit right and there are double ups for some reason.. sorry about that!
Cheers.
Nice work showing pics for all parts :thumbsup:
Do you have window regulator (motor) and switch for R33 S1?
I'm having a problem as this guy:
http://www.skylinesaustralia.com/forums/in...0&hl=Window
I guess I need to change the regulator as the switch looked alright to me.
Hi mate,
Sorry all parts off an R32 which would not suit an R33, especially the window regulator and associated parts.
Cheers
im after the demister vents on the dash.
the long vents running near the front windscreen. Are they straight?no sun damage?
Also a front left wheel hub
Cheers
Patrick
The side air vent? is this the passenger side vent on the dashboard?
• Lower dash trim and side air vent--
This is the one on the drivers side which is part of the plastic cover below the steering wheel, you access the fuses through this cover as well. See picture above.
Cheers
Patrick
Sorry mate, those top strips are gone already. And all hubs have been sold as well.
Edited by trezy85
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
