just a quick one can anyone give me an answer as to weather an ecu from an r33 gtr will run everything in an r33 s1 gtst other than the engine
so if a gtst had an rb26 in it would the gtr ecu be a direct swap over
are all the guages climate control and all that stuff compatible
thanks ppl
Edited by r33rckt
https://www.sau.com.au/forums/topic/176285-gtr-ecu-in-gtst/
You'd need to add 3 (frommemory) additional wires to the ecu's pinout; easily done if you grab a loom ecu plug from a similiar year nissan thats down at the local wrecking yard.
Then you'd be forced to have the ecu remapped. But you loose VCT.
https://www.sau.com.au/forums/topic/176285-gtr-ecu-in-gtst/#findComment-3226186
