Item: Nissan Silvia With RB25DET Conversion
Location: Gold Coast / Car is locked up in the garage all night and whenever its not used / Can ship interstate.
Item Condition: Perfect Condition
Reason for Selling: Going Overseas
Price and Payment Conditions: $23,000 ONO...Open To Real Offers Or Trade And Cash For Cheap Daily (would prefer cheap AE86 or KE70 plus cash)
Pictures:
Mods:
Engine / Driveline
RB25DET Engine coversion
RB25DET Transmission
ARC 400hp Sidemount intercooler
Apexi Pod Filter
HKS Super Drager cat-back Exhaust
KTS 3 puck Heavy Duty Clutch
KTS Soild engine mounts
KTS Soild gearbox mounts
Break mastercylinder flex stopper (under heavy breaking your mastercylinder will flex not now with this mounting kit)
Suspension / Running gear
Weds wheels F: 17x9 R: 17x10
Tein SuperStreet Coilovers / Camber / Height / Damper 32 front 16 back electronically controlled
Tein EDFC electronic damper Controller
KTS 12kg front / 10kg rear coilover springs
Nismo 2way LSD
R33 5 stud conversion
R33 front brakes and rotors
R33 rear brakes and rotors
R33 rear end / handbrake assembly
Custom tailshaft
KTS Rear strut Brace
Looks / Aero
Lexus Tiger Eye Mica paint
Supermade Instant Gentleman full areo kit (only car in whole of Australia with this aero)
Supermade boot spoiler
Supermade roof spoiler
D-Max 45mm Front Widebody
D-Max 45mm Rear Widebody
GTR style front grill
Late model twin headlights
Crystal tail lights
Interior
Drivers side Bride Zeat II seat
Passenger side Bride Zeat II seat
Sabelt Harness
Fullcage 21 safety 7 point
HKS Electronic Boost Controller
Nardi steering Wheel
D-Max VIP dash table
Large rear vision mirror
Double din CD-player / Alpine Tweaters and 6x9's
Large Gear knob
Extra Info:
Car will come with RWC and currently has Rego till the 11th month.
I got this car made up for me cause i wanted a car that had a true Jap style from the aero kit to the interior....
Car was built up for me by a company called AutoPits located in Gunma, Japan about 6 months ago, They fitted the body kit done all the engine and driveline conversion along with the full paintjob.....they done everything. I believe it to be the only car in Australia sporting a full Supermade Instant Gentleman aero kit along with roof spoiler and boot spoiler. Plus full D-max widebody and D-max dash table. Not a single dollar was spaired to purchase the best top brand parts and to try and make a standout Silvia.
SuperMade website link : http://www.super-made.com/
The engine was purchased from a bog stock R33 GTST in Japan and had roughly 90,000k's on it. The engine itself has not seen a singles day hardwork in Japan or in Australia with running standard boost in Japan and in Australia so the car has cause me no issues what so ever. It is one of the smoothest running RB25's i have heard and has no overheating issues what so ever. The engine is all soild mounted along with the gearbox, the KTS 3 puck clutch is firm but not to hard. The car has had full service with timing belts Castrol Edge oil etc.....everything done.
The Suspension is controlled by a Tein EDFC controller which allows you to adjust damper rates from inside the cabin allowing for soft or hard ride 32 point adjustment on front and 16 on back. That long with the 12kg and 10kg spring rates provide a perfect ride. The Nismo 2way LSD is very tight but not harsh.
The car is 100% legal and has all the mod plates for everything from the rollcage to the seats even the 5 stud and break conversion. The car is never a target for the police and the exhaust system is very quite and as soon as they check my plates they see the list of modplates i have and just seem to leave me alone.
Its sad to sell this car as it was going to be seeing alot of drift track work but i am now moving overseas so it has to simply go. Please no dreamers or time wasters.
Contact Details:
Contact me regarding any information you want what so ever.
Mobile : 0423487542
PM Me
MSN : [email protected]
- Luke
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
