Hi all,
I have a series 1 r33 manual with all standard mods. I sourced a new ecu which has been remapped. when the new ecu is plugged in problems arise...
Start car. This seems fine, idle high on cold map as expected. Note i have not tried revving the motor.
Now, here is the really weird bit. When moving the gear stick from side to side revs drop like a small miss and i hear the fuel pump cut out and turn back on. Now clutch in and select a gear and bang she stalls (clutch still in). engine check light is now on. Car needs to be turned off completely to clear engine check light.
Now with motor not running and ignition on (car turned off fully to clear engine check light) i move the gear stick as described above and can hear the fuel pump start priming again. So i switch on keys till red lights on dash (fuel pump primes) then after the fuel pump stops priming i move the gear stick to either the left or right and the fuel pump primes again. Something seems top be triggering this.
I unplugged the new ecu from the loom put my old ecu back in and she works.. Replugged the new tuned ecu into the car ensuring loom was connected tightly and this same thing resulted.
Is there some kind of switch around the gear box which sends signals back to the ecu?
OK ECU serial numbers etc
New tuned rom ecu (problem ECU)
23710-21U01
MEC-R521 A1 4321
Old standard ecu (Working Fine ECU)
23710-21U01
MEC-R521 A1 3X22
Any help would be much appreciated.
Edited by turbs33
I know on my z32, the ecu raised the revs as soon as the gearstick was put into gear. Maybe try checking the wiring diagram to see if there is a sensor(im betting there is)You could try unplugging whatever wire detects that, if its the only problem with the ecu, you may have to live around it.
sounds like the map in the ecu is corrupt, when the neutral position switch is turned on/off (by moving gear selector) its turning fuel pump on and off.
the auto ecu uses this switch to raise idle up and down for when it goes in gear.
the ecu map is corrupt mate, and its using that input to do something other then it should.
or other alternative is the ecu is from another nissan vehicle that uses a different pinout.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
