SmOkEuRbEsMoKeD Posted August 16, 2003 Share Posted August 16, 2003 ok......so my supra is shit right? cuz it has to much horse power. so downshift instead of upshifting. ok i got all that, but one thing i have to ask is "what do u mean by brake" is that the regular brake or the e-brake........when i try to drift i use the e-brake....but i'm trying to use the regular brake now to get the feell for it.....oh and another thing rezz.......when i drift my car goes like this...........straight, turns a little to the left/right depending on the angle of the corner, strightens out for some reason, then turns into the corner, stops sliding, gains traction, and then its over......and when its over i'm 3 quarters the way through a hairpin or a big corner........any suggestions on what the hell goes wrong? cuz i sure as hell dont!!!!! oh and for the 240zx what are the setups for it cuz i dont know what to tweak and what to tweak? thx. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-487929 Share on other sites More sharing options...
Rezz Posted August 16, 2003 Share Posted August 16, 2003 Alright, I have to ask... whats an "e" Brake? When I explained my controller setup, I said "brake" is Square button, and "Handbrake" (sidebrake in AmEnglish?) is Cicle button. When I explained above, I meant the "brake", not the "Handbrake"... (f@ck, why was that confusing?) ...as a side note, I'd recommend you don't get into using the handbrake just yet. Get the hang of entering the corners correctly first. I'd say that when you said "it turns a little... then straightens out a bit for some reason", it's because your allowing the car to regain traction. For a lefthand corner: Approach the corner at about 100km/h (60mph?) and turn full-lock to the right, then full-lock to the left, at the same time you turn full-lock to the left, give it full throttle to initiate wheelspin. As the cars rear end gets about 30 degrees out, countersteer to the right to "catch" the momentum of the rear end. To sustain the "drift pose", keep steering between dead-center and full-lock right, while "tapping" the accelerator button to keep the car at about 30 degrees angle. Try these settings for the 180SX (240?sx in the US? I don't know): The Nissan 180SX is the best drift car. The SR20 powered Silvia`s are also good, but the S15 is a little too top endy in it`s power delivery, so to keep it sliding at the limit is more difficult than the others. Why the 180? Well, the SR in that model (in the game) has the bulk of it`s torque around 3-4000rpm, you need this to be able to tap the accel and get instant wheelspin at lower speeds, and to be able to "steer" the car with the throttle. Also, on it`s lowest ride height at the front, the 180 has excellent stance making the front end really stable... this is apparent in the low to mid-speed corners. The settings: SUSPENSION Spring Rate: (F) 5.2 ®16.2 Ride Height: (F) 89mm ® 89mm Damper Bump: (F) 2 ® 8 Damper Rebound: (F) 2 ® 8 Camber: (F) 10.0 ® 2.0 Toe: (F) 2.0 ® -2.0 Stabilizer: (F) Level 1 ® Level 7 BRAKES Brake Balance: (F) 20 ® 15 GEARING L.S.D. Initial Torque: ® 30 LSD Accel: ® 40 LSD Brake: ® 30 GEARBOX 1st: 3.012 2nd: 2.302 3rd: 1.820 4th: 1.501 5th: 1.245 6th: 0.874 Final: 4.083 Auto Setting: Level 21 ASM (Active stability controller) and TCS (Traction Control System): Obviously set to 0. *edit* IMPORTANT! Super Soft slicks on the front, with normal tyres on the Rear. Also, fully tune the engine, 500+ps is perfect power, no too much for the slow stuff, and not too little for the high-speed corners like at Apricot Hill. Explanation: Honestly, keep the Camber set to 10 degrees on the front. This "lowers" the car even more, and it increases the overall track width, giving more stable (and higher speed) drift ability. The gears ARE THE MOST IMPORTANT!!! That box is set. You won`t need 6th, and the other gears are set so close that it provides power wheelspin at any time (just select the right gear for the trackspeed). Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-487990 Share on other sites More sharing options...
GFXman Posted August 16, 2003 Author Share Posted August 16, 2003 haha i said it before and i'll say it again YOU'RE A NUT! LOL Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-487999 Share on other sites More sharing options...
Rezz Posted August 16, 2003 Share Posted August 16, 2003 Originally posted by GFXman haha i said it before and i'll say it again YOU'RE A NUT! LOL Aye, thaat be true meeete... Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-488048 Share on other sites More sharing options...
funkymonkey Posted August 17, 2003 Share Posted August 17, 2003 e brake = emergency brake, hardly anyone calls it that, but its the hand brake Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-489021 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 18, 2003 Share Posted August 18, 2003 thx guys i'll get started on that car spec asap. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-490119 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 18, 2003 Share Posted August 18, 2003 well guys i'm bout ready to give up.......i just cannot get it right......lets face it guys. i suck at drifting. i just dont no damn clue as what to do (hey that rhymed). rezz i really need a video thats shows what ur doing.....ya know when u go into the replay options and u can set up this thing where it shows when ur braking and accelarating and steering. if i could see something like that i think i would know what the hell to do.....but until then i just gonna stick to grip driving i think Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-491172 Share on other sites More sharing options...
GFXman Posted August 19, 2003 Author Share Posted August 19, 2003 hehe, try and find some real drift videos or tips on real drifting. Its pretty much the same. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-491537 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 19, 2003 Share Posted August 19, 2003 yes i know that but i need a video that tells me whats happening while there drifting EX: when there drifting around the corner it would tell me whats happening like when to downshift when to brake when to give it throttle when and when not to counter steer. ya know stuff like that Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-492935 Share on other sites More sharing options...
Sil8ty Posted August 20, 2003 Share Posted August 20, 2003 Got my self the DRIVING FORCE Steering wheel pac for me PS-2... What a difference it made to my drift career in GT-3.. Better than in my own car on the road.. Cheaper on tyres too.. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-494020 Share on other sites More sharing options...
GFXman Posted August 20, 2003 Author Share Posted August 20, 2003 cool. I might break out the wheel; see if it helps me at all. Haven't even tried it Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-494046 Share on other sites More sharing options...
Rezz Posted August 21, 2003 Share Posted August 21, 2003 I got the GT Force wheel, but connecting drifts (requiring a furious right full lock-left full lock action) almost had me snapping the wheel off... ...not to mention wierd "handbrake on the steering wheel" button location. Much prefer a real handbrake for sure... aaah Logitech? How bout it? Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-494942 Share on other sites More sharing options...
GFXman Posted August 22, 2003 Author Share Posted August 22, 2003 ok, i have been playing around some more with my drifting style. Still faaaaaarrrr from perfect but getting the hang of it now. Lots of subtle control is required I'll try and get a video of it over the weekend. Then you can comment on my technique I have found the Mazda RX7 RZ a really nice car to drift. Will post my setup settings too. Rezz, I really didn't find your settings worked for me... dunno why. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-496935 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 26, 2003 Share Posted August 26, 2003 hey i tried a sprinter trueno gt apex (ae86) and it drifts really nice.....only downside is that it isnt very fast.....plus those specs u gave me rezz didnt really work, all the car did was just spin out....i dont know what happened but that 240sx thing just didnt have enough go for me.....can one of u try to find a fast good drifting car? Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-503096 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 26, 2003 Share Posted August 26, 2003 also i want to ask rezz and gfxman if u guys are interested in building a project car in GT3? if so just e-mail me at [email protected] . Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-503098 Share on other sites More sharing options...
GFXman Posted August 27, 2003 Author Share Posted August 27, 2003 huh? please explain :confused: Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-503565 Share on other sites More sharing options...
GFXman Posted August 27, 2003 Author Share Posted August 27, 2003 Okay, I agree with Rezz - the 180sx (or 200SX Type X in AUstralian GT3) is by far the best and easiest car to drift in. Here are the settings I use: Car: Nissan 200sx Type X Mods: Everything Approx HP: About 460hp ----- Tyre Choice----- Front: Racing Super Soft Rear: Normal ----- Suspension ----- Spring Rate Front: 6.0 Rear: 7.9 Ride Height Front: As low as it can go Rear: Just a touch higher than the front Damper Bump Front: 5 Rear: 7 Damper Rebound Front: 6 Rear: 7 Camber Front: 10 Rear: 0.5 Toe Front: 0.5 Rear: 1.5 Stabiliser Front: 3 Rear: 3 ----- Brakes ----- Front: 4 Rear: 24 ----- Gearing ----- LSD Initial Rear: 50 LSD Accel Rear: 50 LSD Decel Rear: 10 Gear Ratio I just set this to be about 21 or 22 (auto setup) and then changethe 6th gear to be as low as it will go. This gives you maximum torque in all the gears but lets you stretch the legs a bit on 6th. ----- Others ----- Down Force Front: n/a Rear: 0 Traction Control 0 Stability Control 0 This setup I have found gives awesome control of the car. Extremely responsive steering and so much available torque you can spin the wheels in any gear. For an explanation of drift techniques. It even explains how to do them: http://www.driftsession.com/technique.htm I find that my style of drifting is mainly the Feint Drift and Power Over. However I also use the other styles when needed like Braking Drift for slow corners, E-Brake Drift for quick flicks like linking corners and Kansei Drift for high speed corners. Hope this helps some for those having troubles. I'll try and get some footage of my drifting asap. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-503593 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 27, 2003 Share Posted August 27, 2003 gfxman and rezz what i mean by a project car is a car that a few people take and mess around with....like u me and rezz can take...oh lets say a supra and tweak it and see whos specs work the best.....so if u are interested just lemme know. but anywho thats what a project car is Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-504820 Share on other sites More sharing options...
SmOkEuRbEsMoKeD Posted August 28, 2003 Share Posted August 28, 2003 its basically a project that u work on and see how it goes i guess. Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-504890 Share on other sites More sharing options...
GFXman Posted August 28, 2003 Author Share Posted August 28, 2003 well i figured that ... but just wasn't too sure how it would be done in GT3. i get it now Link to comment https://www.sau.com.au/forums/topic/17632-gran-turismo-3-drifting/page/4/#findComment-505014 Share on other sites More sharing options...
