My question is more on the way its fitted.. If it needs a pin throgh it, to be sure it wont spin on the crank.
Now its mounted this way: crank was cold shrunk, collar heated to 100 degress, both parts degreesed, special glue, VERY strong and will hold up to 150 degrees, still needed 2 tons to be pressed on. (No I did not press 2 tons down on entire crank, a metal bar was fitted just down under the first counter weight.)
Question is, do you think it will stay on and not spin round the crank. I dont know how much force there is trying to twist it around the crank.... How hard the oil pump is to drive..?
https://www.sau.com.au/forums/topic/176327-is-this-okay/
Rule of thumb from an old engineer when they used to press on drive sprockets. A 2 thou tolerence fit on a 1 inch pipe 1 inch wide will drive 40hp.
Thats an interesting rule of thumb when you think about it, as HP doesnt have anything to do with it does it!
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226313
It's to do with torque and how much pressure is being created outwards on the outer surface with the interference fit.
https://www.sau.com.au/forums/topic/176327-is-this-okay/#findComment-3226340
    • I'll measure it up at the lowest point later and post it up Currently painting, with the oven all warmed up to 93°c
    • How much clearance is under the car? We have speed humps being added everywhere around me. Faster than they fix the potholes, thats for sure.
    • After some googling of various websites IRT the best ride height for correct geometry I ended up going,  hub to guard, 330mm in the rear and 345 at the front, these heights came from Flyin' Miata in the states as what they recommend (13" rear, 13.5" front) The rear needed to only come up 5mm, but the front came up 15mm Overall it is around a 25mm drop from OEM ride height, doesn't look all 4x4, and hopefully should be enough height to clear those pesky speed humps I have lost around 0.5° camber on the front, and around 0.2° in the rear, I have no idea about what it did to toe settings so I'll look at a new alignment next week to get it set up how I want, zero rear and a little in at the front I've also stripped the new intake and am currently cleaning and preparing the alloy for some paint, I've headed into work to do it as I can use the ovens in the soils lab to cure the wrinkle paint at 90°c Jackie has banned me from using the oven at home for stuff like this....🤣
    • At my age, 59, I'm in bed by 20:30 nowadays 😴 I'm pretty much a solar powered device, powering up at first light, and powering down when the sun goes down 🤣 Oh to be young again.....
