The 2835 Pro S and GTRS are quite close in performance i believe, i know they're different but just doesn't seem to be much on paper.
So, when considering the 2835, the exhaust flange will definatley need to be custome made from what I've read and seen.
And i think you need an extra spacer to stop it touching the engine block.
THere's a thread on the 2835 install somewhere and there were a few headaches to get around but obviously do-able and worthwhile.
On the other hand, the GTRS is an easy swap out using the stand zort flange. Easy peasy.
I think you can forget my last post.
I can't remember which turbo i was thinking about??? but i do remember that bent bit of wire that's in the pics.....
Just found a thread on the install and it looks sweeeet.
http://www.skylinesaustralia.com/forums/in...;p=1742392&
Yeah, most turbos you;ve mentioned have T3, don't worry about that.
Just some people don't advertise all options on their sites so be sure to do thourough seaching before giving up.
Nengun.com has the kits for both showing the T25 and T3 options, that's where i usually start my searching.
Edited by Birnie
I seriously stay steer clear of the 2835Pro S and 3037 Pro S (is there even such a thng?). These turbos perform much better with an external gate. the pro S versions having internal gate compromises their exhaust housings a lot. external gate is the go.
NOT exactly bolt on but i put together a kit for a guy in NSW last month.
T67-8cm with manifold gate etc...
over 213rwkw from 3000 and peaks at 270rwkw @ 17psi better all round HP and torque (up to 35-40kw down low) over the Garret GT35 that it replaced.
if anyone went to DA round 3 at eastern creek it was the Yellow R34 in super drift putting on the biggest smoke show of all the cars there.... tuff setup... best R34 GTT RB25 setup i have ever driven actually.
i will get his dyno graph to post up.... super responsive with decent top end. Not much more than 270 is possile with the 8cm rear though.... need to upgrade to 10cm to crack 300rwkw.
I still reckon from how my GT3076R drives that a bolt on GT3037 from HKS will meet most of those requirements. They will pull hard to redline, have excellent response, make good power, and have an awesome midrange whack.
If I did it all again, I'd not go smaller than a GT2835/GT3071R but not go bigger than a .82a/r GT3076R.
is ur turbo GT3076R .82ar?
when does it come on full boost in 3rd?
how would you think it compares to the HKS 3037 equivilant?.
do you think a .71 custom gtst housing would be good?
im taking the plunge and im stuck on turbo choice, also.
cheers,
Edited by silverbulletR33
2835 pro s is a bolt-on, if you buy the kit, it fits perfectly and comes with the dump pipe already. didnt take me long to install mine the only problem i found was that when tring to tighten the bolts that connect the turbo to the manifold it was tight fit to get the socket in there.
Also you dont need a dump pipe gasket if you but the KIT, as after tring to find one for my kit, i ended up calling HKS and after them sending me the wrong gasket 2times they told me they made a mistake and the gt2835 pro s kits dont need a gasket at all, ive been running mine for almost a year without a gasket and no problem at all!
internal gate is ok! lol ive got one, much cheaper going internal too :D
what car do you have and is the engine using stock internals?
R33, my engine internals are all stock, my engine has done 100,000km and i made 350hp @ 16psi without a problem
I have a .63a/r, I have full boost ~3500rpm in 3rd - very hard to tell because it sweeps past those revs too quickly, which has to give some kind of idea of what its like :P
Depends on which GT3037... the 56Trim GT3076R will spool exactly the same as a 56T GT3037 running the same turbine a/r.
I think I'd be happiest with a .71, it spools REALLY quickly for the size with the .63 (easily quick enough) but the extra increase to .71 would probably make it a little more progressive and allow it to flow a bit better up high.
Me and a mate actually drove each others cars back to back this weekend actually - he has a R32 GTSt with a S2 RB25DET running stock turbo still. Driving impression, his is way better than mine up to 2500rpm under foot... then 2500rpm to 3000rpm his is noticeable better but nothing exciting, then from 3000rpm onwards mine feels like its made up all the difference and is keen to show stock turbo who's boss.
Hey Lithium don't suppose you have a dyno graph handy?
whats your peak power/boost used to get there?
Im watching with interest because Im close to upgrading myself and am sorta tossing up between the HKS GTRS or a garrett 3076 .63 rear but 52T. . .
emphasis on mid range but with 300+ hp atw
internal gate is ok! lol ive got one, much cheaper going internal too :(
well yeah they are ok, but for 300rwkw on a GTT or GTST I would definately be going external. the IG housings of turbos this size are not such a good compromise. i mean you know what the shape of the IG 2835 is... not good. sure the IG 2835 kit is cheaper but it's not that expensive to go External and for 300rwkw it's a better option.
Im watching with interest because Im close to upgrading myself and am sorta tossing up between the HKS GTRS or a garrett 3076 .63 rear but 52T. . . emphasis on mid range but with 300+ hp atw
How much more than 300hp? The area of around 300whp-350whp I'd just go with a GT3071R. I haven't had a full tune as the car has had a niggling boost control issue for ages, its getting a bunch of stuff changed over the next month which part of the result should be better boost control.
There are dyno plots on here of people using GT3076Rs though...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
