Hi All,
Just thought I'd post a shameless plug for the good guys at Brakewest in Victoria.
Brakewest is a brake and clutch specialist shop... not nessicarily high performance but they obviously know their two left peddels very well.
I ordered a front and rear set of braided brake lines from Goran around lunchtime (WA time) and they were made up, sent, and arrived first thing this morning. They are excellent quality ADR approved lines made from stainless steel with a clear sheth over the top. They are pressure tested to 3000psi.
I assume prices will vary from car to car (depending on fittings required), but my 32GTR set was $250.00 and $12.50 for express postage.
Awesome service, quality product, good price... cant ask for more than that.
BRAKEWEST
https://www.sau.com.au/forums/topic/176343-braided-brake-lines/
any idea how differet 32 GTR and GTST lines are? if at all?
I had some GTR lines modified to GTS-t. The rear lines are definately the same but the fronts need to be about 20cm longer I think. IIRC it came out to 60cm once you remove the hard line from the back of the caliper, better you measure it though.
Just to clarify, you are saying you had to get the front GTR lines lengthened to fit your GTSt?
I was planning to buy some off the shelf specifically for a gtst so I can do all the brakes stuff at the same time instead, but all I can find are like $400-500 jobs.
Edited by bubba
Maybe try the mob the Godthrilla used? If they have them for GTR, 1 would assume they would have GSTt ones aswell.
Also, he didnt seem to have any trouble dealing with them.
yep, cost me $60 at Pirtek osbourne park (or enzed.. can't remember but its on frobisher)
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
