Sorry to ask what might be a dumb question, but how many boost controllers should be required on a 32 GTR (yes it is still running two turbos).
My mechanic has just installed two boost controllers as part of some work he has been doing on the car. He had first installed just one controller, but found that this did not work, so he has installed 2 now, one between each turbo and the actuator. Just wondering whether this sounds right?
Any help would be appreciated, a lot
You only need one boost controller if correctly setup.
He didnt do it correctly if "one" didnt work.
I would suggest another mechanic. He should know how to setup boost control on a GTR if he has any idea about twin turbo applications
The more the merrier I say..
For double points see if you can get 2 boost controllers PER turbo.. :dry:
Again.. might be a silly questions..
..BUT..
If you have a boost controler PER turbo.. you can change each turbo's boost pressure..
so.. can you get one to come in early with a small amount of boost.. and another with a lareger amount of boost later? I.e sequential turbo?
..just a thought..
..BUT..
..just a thought..
that wont change WHEN the turbos kick in as they'll both be producing the same boost at any given psi. only difference is one will have a higher limit.
GTS - Hahah, nice try, though no
Sequential setups work because the turbos themselves are of different size / AR etc. An single EBC that allows you to control the solenoid through out the RPM range, and with proper gain control should grant you your wishes, and control the twins.
Edited by GeeTR
Secur1ty, could you please explain the part about one of the turbos having a higher limit?
Is there any problem with running two boost controllers? Or should i take it to someone else and get one removed and the other set up correctly? Or if someone can show me a pic i could do it myself :)
i was saying that if you're running 2 separate boost controllers it will be hard to determine which one is pushing more psi than the other unless you use 2 electronic boost controllers. with a single boost controller you'll have an even spread between them no matter the type. even if it spikes, it will spike evenly :)
for eg, 2 scenarios:
1st is the 2 boost controller setup.
lets say the boost gauge is reading 14psi. with 2 boost controllers you may not have an even spread as one turbo may be pushing 4psi, and the other 10psi. you cant tell.
this will cause one turbo to always be overworked.
but hey, at least you'll have 1 turbo in VERY good condition which you can sell to help with your rebuild.
2nd is single.
even spread, easily manageable. no dramas.
all you've got to do is get one of the vacuum hoses coming from one turbos wastegate actuator, then get a T piece and plumb it into the vacuum hose going to the wastegate actuator of the other.
i was saying that if you're running 2 separate boost controllers it will be hard to determine which one is pushing more psi than the other unless you use 2 electronic boost controllers. with a single boost controller you'll have an even spread between them no matter the type. even if it spikes, it will spike evenly :P
2nd is single.
Ahh i see what you mean with the different levels of boost. That was one of my concerns too.
I've revised my diagram according to what i understand you saying with the T piece etc. Would you mind having a look at the attached dodgy paint thing ive contructed and see if i've understood correctly? Is everything positioned correctly here? And do i simply plug the second hole created from turbo inlet 2?
Thanks again :D
Edited by Jpowys
The controller really needs to be connected to both turbo intakes.
The other thing, I thought that wastegate actuators were connected to the turbo outlet.
Such as this one, because the daiphram is operated by air pressure which opens the gate.
Edited by Slim Mat
what about boost duty?. doesnt this allow you to make the turbo work harder or less, to enable users to compensate for old worn out turbos etc or to create a better boost curve? with AVC-R
so you could have 1 set to come in early as possible, hit max boost , then taper. have the other duty lower, then later in the rev range - set NE points to induce higher duty with higher limit?
could this work?
thats how all boost controllers work mate, only difference is that the max boost is limited by the wastegate actuator itself (i.e. what the spring is rated at in the WA).
to turn the boost up you add a boost controller between the boost FEED (which is anywhere on the inlet piping including the turbo itself) and the wastegate actuator.
could this work?
no it couldn't.
Solenoid "Duty" is the pulse rate to the solenoid (which dictates boost level)
"Gain control" is better described as the speed in which the EBC moves between the duty needed to hold the gate shut (so off boost) and the duty needed to maintain the set boost.
Gain controls the rate, or intensity in which boost builds to the set user set limit.
This is my understanding, until i learn otherwise :P
M
Secur1ty : Sl!m Mat was just trying to point out that the reference had to be taken from the turbo outlet, not the turbo inlet..
just to clarify for the original poster, as it differs from that mspaint drawing posted.
james.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
