hey all .
im new around here just joined up as my current car is for sale and i am looking for a r32 gts-t.
but i have a few questons regarding them:
do all series r32's come with the projector headlights? or just the late model ones?
what is the differences between s1 and s2?
anything i should look out for when looking at a car? i.e rust in common places etc?
also if there is anything you want me to kno about when looking at them plz tell me.
cheers
jono
https://www.sau.com.au/forums/topic/176358-r32-gtsts/
projector headlights came in series 2 r32's
Difference between series 1 and 2 include;
- s2 heavier by a bit due to reinforcement bars in doors.
- Different steering wheel (tried fitting s1 wheel onto my s2 r32 yesterday, completely different setup yet they look the same)
- s2 plastic interior is the rough grainy look, where s1 has smooth plastic around the headunit etc
- s2 has grey faces on the dash, where s1 has blue
- s2 has a different ac compressor
- s2 has different interior cloth on the seats
- s2 most come with electronic front spoiler (although i think its an option)
There is a lot of small differences between the two series' but they all make a difference :thumbsup:
https://www.sau.com.au/forums/topic/176358-r32-gtsts/#findComment-3226726
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
    • I had my car model wrong on my Shannons insurance when i had my V36. didn't make a difference when i claimed a windscreen. Nightcrawler is a negative nancey 🤪
