Winton Sprints - Sat 28 July - Club C/ships Rnd 5
  • Replies 105
Posted Images
RE Customs Represent!!! I'll be there testing out my new suspension. Ray should (hopefully) also be there with his new & improved weapon of choice :nyaanyaa: RWD modified class will hopefully be alot of fun this round :blink:
I wonder if Dane will be in for this round??
Is the silver bullet coming out to play bris?
Meh, depends if i can get more then 2 hours sleep anytime soon, and get on top of work. The only way stuff is getting done on my car is to pay someone...which means it wont be happening. Maybe this weekend ?!?!?!
I should be in - Need to sort tyres. But i'll be there anyway.
JT from autobarn Narre has a near new set of RE55's going pretty damn cheap.
Hey all,
Im just a little confused still on the driver training front.
It does have "novice" on the list of 2007 classes in the supp regs. But if i look at the running sheet for the day it doesnt list the training blocks which i thought they had at the sandown rounds supp regs?
The entry form also asks for an expected lap time, can i just leave that blank as i have no idea / will be slow no doubt.
and last but not least do you have to sort out the number to stick on the car or do the organisers/cams hand them out on the day?
thanks heaps everyone
Camden
Hey all,
Camden
Hi Camden,
For your class write DT, leave the expected lap time blank, you will be given a number on the day
cheers,
Budge
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
