When it collapsed, what did the car actually do? Did it just lose all power and not make any more? What made you know it was the cat?
was on the dyno for a tune, but made same as before with too much timing
as soon as I picked it up it felt restricted, could tell really, tuners said check the cat and fix the fmic pipe
so checked the cat, was all warped inside and bent, cleared it out, then back on the dyno to fix the crap tune
206kw at 14psi, but the turbo is now the restriction - then redid the fmic so it works real well now, as 1 corner was warped and not letting thru 100% volume
now with 16psi feels fantastic, reckoning around 210kw dynobum
down 25kw with the turbo, so looking for a garret bb I can alter with my housings to harness 235awkw (auto heavy stag)
headwork makes the engine feel like a 25/30 so Im happy as larry, just need to get a better flowing bb turbo
  • Replies 52
Posted Images
I had a metal cat (barrel type) last for two years then finally kark it on a dyno tune. Went from 20psi to 11psi due to guts of cat blocking the exhaust a little. It was rattling around due to it separating from the body. Bits were shooting out the back lol.
Anyway, ended up getting a new one and this seems to be the mark II. It has a rod welded across the back of the matrix to stop the guts moving around I guess when it heats up and cools down.
I'll see how it goes.
I reckon thats more work than unbolting the exhaust from the front pipe (because you've gotta get a pressure sensor then :P)
Yeah i guess so for those , but its something to keep in the tool box forever once its done...... i should make a heap up and sell them i think !
I do far to many cars to not have one with me..... and ALL dyno shops should have one anyway ! So easy to just whack it in and log on a second map channel. !
Hey i just re-read your comment and you said "you've gotta get a pressor 'sensor'" ...... all i mean is make up an adaptor (18*1.5mm thread to hose barb adaptor, and using some silicon hose , plumb it to a spare, or your current, "BOOST" gauge ...) ...can't get much simpler than that !
Gary
my 5inch catco went the same way as sean gtr's.
It just worked it's self loose around the edges and proceeded to unravel from the outside of the substrate.
The outsides of the cat didn't have a mark on it from scraping or anything so i figured it was a manufacturing fault. other than the separation the guts looked good, no melting or whatever. It got punched out and flames started to appear on over run :D
Turbine Inlet Pressure. Anothers words, measure the pressure in the exhaust manifold. This will give you the info to work out the MIP to TIP ratio ( boost to exh mani pressure) , If its over 2:1 then your in trouble.
With high exh backpressure, due to small turbo housings or restricted exhaust, larger overlap cams just give it more time to pollute the intake charge more, and drop the knock point, resulting in less power.
Hence why changing to a larger exh housing generally allows more timing to be added, due to less intake charge poluting.
If you've run out of things to check, this is the ultimate thing to check to check the turbo sizing to the job your asking it to do. Bit of an effort , but its quality data when you get it.
Gary
Edited by Fastrotor
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
