Today i turned off my Profec B for the first time and let the wastegate set the boost level.But it seems as the revs rise so does the boost.It hits 7-8psi then as i go over 4500rpm it slowly climbs and has gone as high as 9.8psi.
Is this boost creep??
And would a HKS actuator fix it??
CHEERS
https://www.sau.com.au/forums/topic/176433-boost-question/
I could be wrong here and want to understand why, but if you turn your profec off how is your actuator going to get a signal to open the wastegate.
Logic tells me that without a signal of any sort, your boost will just continue to build with revs.
https://www.sau.com.au/forums/topic/176433-boost-question/#findComment-3228159
Even with the boost controller turned on the boost still rises with the revs.But just happens at a higher boost level.
Eg: Turned off- boost is at 7psi then rises with the revs to 9ish psi
Turned on- boost is at 12psi then rises with the revs to 13.7 psi
Does anyone know why this would happen???
https://www.sau.com.au/forums/topic/176433-boost-question/#findComment-3228660
Okay, I may be able to offer some assistance here.
I have just finished a HKS 2835 ProS (internal wastegate) turbo upgrade due to failure of stock turbo.
The car spent 3 hrs on X-speeds dyno and came back a setting of 55% duty cycle in manual mode.
I was quite happy with this setting however the initial boost pressure can be a bit inconsistant depending on the outside air temperature variation.
In the morning the turbo comes on hard at 16psi. In the middle of the day the boost comes on at 12 psi which I find a bit annoying.
So in the bid for a more consistent boost response I first tried playing a bit with the actuator rod length.
Initially I set the wastegate to be visibly opening at 10psi and be fully open by 12 psi using compressed air.
X-speed seemed happy with how the actuator was operating and used the controller to do the rest.
I, like yourself, thought I could a better result than the blitz-ibc using the actuator spring preload itself. How wrong I was.
After a fully day of experimentation I verfied this to be the optimum actuator rod length setting. If I make the actuator any stronger I end up over-boosting at around 6000rpm. Any less and the solenoid was having to do too much work.
To verify the effect of the actuator length changes just leave the EBC powered on and set the duty cycle to 0% (or fully open).
I found actuator-only control gives a steadily increasing boost pressure from 6 psi at 3500rpm to 12psi at 5500rpm and then drops back to 10psi by 7000rpm (boost creep).
So, contrary to car magazine theory it is not possible to obtain good boost control just through actuator adjustment only.
In fact, I found actuator only control to be very poor as it brought the turbo on too hard and too quickly over a narrow rpm range resulting in high knock.
This is something that X-speed warned me and they were correct.
Following some more highway tuning I think I now have a good setting which seems to give a more consistent result.
- Actuator opens at 10psi.
- Solenoid duty cycle 70% open for 0 - 3500rpm, 65% for 3500 - 4500rpm, 55% 4500 - 5500 rpm, 48% for 5500rpm - 7200rpm.
you need a 4 channel EBC to do this.
I know that the Blitz, E-Boost and the AVC-r potential have this capability in one way or another however I am not familiar with the Profec.
Using this downward sliding duty cycle boost commences much earlier at 3000rpm with 16psi and holds to 4500rpm and then steadily drops to 14psi at 7200rpm. This is a good overall setting since it spools the turbo quickly and then reduces chance of knock at high rpm.
https://www.sau.com.au/forums/topic/176433-boost-question/#findComment-3229610
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
