[Mark here... This is seans car, he crashed it and done a bit too much structual damage so we are writing her off and selling bits.. its repairable. but requires chassis rail alignment and a bit of cash.. and would rather build a RB25Neo 180sx/s13... so will trade alot of parts and or cash for a working/regoed 180sx/S13 with a clean body. if you know of any there will be a small spotters fee aswell. :(. must be rust free clean, good interior. dont care about engine.. prefer CA18 and manual :rofl:
Sean has made this ad using my account and all enquires should be directed to him on 0417784987 NO SMS. -
you can also call me on 0400 793 618. NO SMS' thank you.
thanks
mark.]
R34 2dr GTT Tiptronic
Purchased as a Grade 4.5 car and is extremly clean.
colour is pewter
Motor has 55,000ks on it
has a full turboback exhaust Jasma/blitz cat back with unknown high flow cat. flyn front and dump
interior is mint no damage at all
tail lights are still good
all glass is good.
RHF guard is good but scratched on top. also have LHF headlight lense with scratches on it.
rear subframe (bent RHR LCA) $700 with diff.
Diff perfect condition recently serviced $350.
Coilovers are fully adjustalbe Ohlins (top model for the R34 when purchased) that retail close to $5000(including fitting weight corner balancing) new used for round 10,000km
also have some volk TE37s 18x8.5 n 18x9.5 wrapped in POTENZAz Re040 235/40/R18 and RE01 265/35/R18 on the rear one with minor damage and one needing repair ... tyres have 70%-80% all round fronts are 2 months old.
unfortunately front n rear bar, front right guard, boot are damaged, also had a front mount but only the core is left... (JJR Bar and plate type 2 very similar to the Trust kits)
just let me know what you want and asking price :rant:
can take pics of anything if needed
and welcome people to come round and have a look.
cheers
PS. please only post if you are interested in items thanks. :rofl:
Edited by markimak
https://www.sau.com.au/forums/topic/176434-wrecking-r34/
  • Replies 63
holy batman..what happened??!!
Might be interested in the lower dash console piece depending on how much u want for it. Mine's got a broken clip on the right hand side and never sits flush.
See pic circled in red.
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3228074
thanks mark
for the one interested on the intercooler i jst took a pic as it was straight off the car, sorry if its DIRTY !! no real big scratches on it does hav a lil coolant stain or sumthin on the left that ill kinda wipe off n take another pic if u think its hidin damage
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3234746
im interested in the turbo back exhaust.. is it in good condiotinon and info on it?
If it has the factory pop up GPS.. where did they put the 3 gauges??
Edited by Silver_R34_GT-T
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3235027
I'll try to be of some assistance, hope u dont mind marki....
The catback is Jasma and sounds really sexy, probably the best RB25 rumble I've ever heard. The dump/front section is from FLYN performance and set Sean back $280 not even 3 months ago. I'm pretty sure the cannon is the only part with a few dings on it, have to wait for Mark or Sean to reply for confirmation there. It's a quality system and you wont regret coming down to have a look I'm sure.
The 3 gauges were an optional extra that the original purchaser obviously didn't bother with, not all GT-T's have them.
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3235766
exhaust as said above is a jasma catback, only one dent underneath the cannon pretty sure it will hav no effect on flow or make any leaks, front is from FLYN and did set me bak $280 i think only a month or so ago.
as stated R34s hav options such as 3 gauges, GPS/Nav/TV or nothing... this GTT got the luxury GPS one so ther is no gauges other than the ones on dash (oil pressure, fuel and water temp)
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3236005
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
