[Mark here... This is seans car, he crashed it and done a bit too much structual damage so we are writing her off and selling bits.. its repairable. but requires chassis rail alignment and a bit of cash.. and would rather build a RB25Neo 180sx/s13... so will trade alot of parts and or cash for a working/regoed 180sx/S13 with a clean body. if you know of any there will be a small spotters fee aswell. :(. must be rust free clean, good interior. dont care about engine.. prefer CA18 and manual :rofl:
Sean has made this ad using my account and all enquires should be directed to him on 0417784987 NO SMS. -
you can also call me on 0400 793 618. NO SMS' thank you.
thanks
mark.]
R34 2dr GTT Tiptronic
Purchased as a Grade 4.5 car and is extremly clean.
colour is pewter
Motor has 55,000ks on it
has a full turboback exhaust Jasma/blitz cat back with unknown high flow cat. flyn front and dump
interior is mint no damage at all
tail lights are still good
all glass is good.
RHF guard is good but scratched on top. also have LHF headlight lense with scratches on it.
rear subframe (bent RHR LCA) $700 with diff.
Diff perfect condition recently serviced $350.
Coilovers are fully adjustalbe Ohlins (top model for the R34 when purchased) that retail close to $5000(including fitting weight corner balancing) new used for round 10,000km
also have some volk TE37s 18x8.5 n 18x9.5 wrapped in POTENZAz Re040 235/40/R18 and RE01 265/35/R18 on the rear one with minor damage and one needing repair ... tyres have 70%-80% all round fronts are 2 months old.
unfortunately front n rear bar, front right guard, boot are damaged, also had a front mount but only the core is left... (JJR Bar and plate type 2 very similar to the Trust kits)
just let me know what you want and asking price :rant:
can take pics of anything if needed
and welcome people to come round and have a look.
cheers
PS. please only post if you are interested in items thanks. :rofl:
Edited by markimak
https://www.sau.com.au/forums/topic/176434-wrecking-r34/
  • Replies 63
holy batman..what happened??!!
Might be interested in the lower dash console piece depending on how much u want for it. Mine's got a broken clip on the right hand side and never sits flush.
See pic circled in red.
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3228074
thanks mark
for the one interested on the intercooler i jst took a pic as it was straight off the car, sorry if its DIRTY !! no real big scratches on it does hav a lil coolant stain or sumthin on the left that ill kinda wipe off n take another pic if u think its hidin damage
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3234746
im interested in the turbo back exhaust.. is it in good condiotinon and info on it?
If it has the factory pop up GPS.. where did they put the 3 gauges??
Edited by Silver_R34_GT-T
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3235027
I'll try to be of some assistance, hope u dont mind marki....
The catback is Jasma and sounds really sexy, probably the best RB25 rumble I've ever heard. The dump/front section is from FLYN performance and set Sean back $280 not even 3 months ago. I'm pretty sure the cannon is the only part with a few dings on it, have to wait for Mark or Sean to reply for confirmation there. It's a quality system and you wont regret coming down to have a look I'm sure.
The 3 gauges were an optional extra that the original purchaser obviously didn't bother with, not all GT-T's have them.
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3235766
exhaust as said above is a jasma catback, only one dent underneath the cannon pretty sure it will hav no effect on flow or make any leaks, front is from FLYN and did set me bak $280 i think only a month or so ago.
as stated R34s hav options such as 3 gauges, GPS/Nav/TV or nothing... this GTT got the luxury GPS one so ther is no gauges other than the ones on dash (oil pressure, fuel and water temp)
https://www.sau.com.au/forums/topic/176434-wrecking-r34/#findComment-3236005
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
