Put the VG30 in a cardboard box. The walk into the garage and slide it under a bench. The best place for it. Then when you see an R33 owner wanting to hi-flow their std turbo then sell them the turbo so they can use the larger exhaust housing of the VG30 to ring every last hp out of the hi-flow.
Unfortunately the RB20 doesnt have the cc or compression to mask that the VG30 turbo isnt that great to start with, let alone on an RB20
As Roy said dont even waist your money with it as you will have better power and driveability from the stock turbo.
Either hold off until you can find a used RB25 turbo and bolt that up or go a highflow for best bang for buck.
What other mods do you have currently or your future plans for the car and power your chasing as that will also depend on what turbo you go with or if its worth spending money on a turbo now rather then later :P
i had a vg30 turbo on mine. went ok but im now upgrading to td06. my exhaust wheel came off at the track, whacked a std one on to get home and it went better than the vg30, more responsive an wat not. do as roy said. i have a vg30 turbo here with no exhaust wheel if anyones keen aswell
alright so rb25 turbo wat has 2 be done 2 fit one?
theres a diy in this section somewhere, covered in detail, however its is a direct bolt on everthing is exactly the same, i just changed my mates one last weekend only too a couple hours, not hard at all, just find a cheap rb25 turbo heaps going round, i have one if you want.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
