I spent over 4h hours today watching someone trying to upgrade my immoboliser to an alarm just to fail. Does anyone know of a good place to do it for a V35? I am not going to name any names here, but I think that guy knows a thing or 2 about alarms, just maybe not for a V35.
The OEM one should of been removed and an ADR approved one fitted for compliance, what is fitted to start and what were you up grading to.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3228356
I get my AUTO WATCH alarm fited for $380. That guy spend 3hours analysis all the wires of the security and immoboliser, at last he successbully install a alarm unit and keep the key untouched.
What I got:
Untouched key, all funtions run as factory set.
Alarm system
windows sensers
A suprised funtion, when I click unlock bottom, the tail ligh will on for about 3 second, that is really cool as I seldom see what my car's tail light looks like.
As I understanding, He didn't upgrade the security level, he just put an AUTO Watch unit in between the factory security unit and control, so all the singal will go through the origional unit and then the AUTO Watch unit, then to the control unit. the senser and siren are link to the AUTO WATCH unit. In case if some thing wrong, either from factory code system or new senser, The siren will speak lond.
Pretty good.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3231404
My understanding is the OEM one is to be removed all together as it is not the best plus it does not comply with the ADR's, the one I have fitted activates the boot and door opening/locking as per original in one unit not separate to the key, but people fit the alarm as a separate unit to the key as they cant merge the two together.
It also self arms after a while but I have it set so it doesn't lock the doors, as I have said in other posts the electronics in these cars are not simple or for the faint hearted.
Chris will know more on this then me.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3234574
yep alarm upgrades are the go on these. last 350z I did (similar architecture) they had put an alarm over the OE item- very messy and it didnt work quite right and it was VERY erratic.
nigel,
the OEM thing is a plug and go item anyway. fairly easy to ID and strip.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3234825
nigel,
All I know it is a pain having to use the key and alarm separate as I had another one to day and it is dodgey.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3237142
Anything that will stop my wheels being taken off. So I was thinking shock sensors. Microvave sensors I think are also cheap to install. Would be cool to have sonic sensors in the front so it warns a car in front when it is parking and getting too close, but that will probably cost way too much.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3241283
are you in syd? if so, I know a very good guys can install alram for our car. He can disable the chips from the key to an individual, then you can get a copy of key for few bucks as spare. no way to spend $500 up for spare key from japan!!!
You mean he can also replicate the key so you can get a spare? Wouldn't mind that as recently my key stopped working. Replaced batteries, but still dead. Going to check out contacts today and clean it out.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3241288
parking sensors inthe front is easy. needs a switch to control them but thats it. to do them you need the car paint code and 3-4 hours of time.
as for security - do you want the key only or key and remote? I'll make a few suggestions based on that.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3241473
I got my key to work now, so I am happy with either. I have auto watch remote together with my key to disable the immoboliser.
I have to find out what I have fitted to my car, all in one boot, doors, self arming everything, I never use the origional key to open or lock the door, as I said I had to use a car with both fitted and it pissed me off.
What pisses me off more is you guys are paying good dollar and they are not even doing it right, this is ADR 82/00 which is "Vehicle Standard (Australian Design Rule 82/00 – Engine Immobilisers) 2006"
People think complying cars is easy so have a read of this and this is only for the requirement to put in a basic Immobiliser.
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3245821
amen to that. too many hacks make way too much of a mess of things. great for me , I get to fix them, bad for the customer as they still shop on price and know no different.
one that really spring to mind are the dealer fitted and manufacturer fitted (locally) alarms. the brant (nee subaru now) items I can find and remove in about 3-4 minutes due to the way they are done. they stop some people but not all. same goes with these cars (V35.) reason that you may have ended up with a key (for unlock) and a remote is they simply did not understand the car. these cars run one module that controls the ENTIRE car. fry it and it gets VERY expensive very quickly. some of the jobs I have seen from shops with ADR alarms shock me. (see below.)
click this:
look at the 350Z and the R33. both are shops.
http://www.audioexpress.com.au/shop/HOS/
(still not finished with the pages so its a bit buggy :P )
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3246435
click this:
(still not finished with the pages so its a bit buggy :) )
Yep look at my case , the compliance place has f**ked my v35 and i havnt had it for nearly 6 months
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3275608
It is stories like this that make me glad I decided to buy a car from a local dealer and pay a few thousand dollars extra and get to test drive it first and see that everything is working correctly.
I hope you get it all sorted in the end but does the saving nd waiting seem worth it now?
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3281091
Well i drove the car to compliance, and i got the car at a top price with everything i wanted on it so yeah its still at the moment worth it
https://www.sau.com.au/forums/topic/176463-alarm/#findComment-3282285
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
