Bought these with the intention of running them on my car. Though with a 343mm rotor it means that wheel clearance is going to be very tight on a 17" wheel. (The calipers are bloody big)
Rather then go smaller 332mm rotor want to go to a smaller Project U caliper that will work better with the 343mm rotors
Brand new still in box, they are the big daddy of the 4 piston caliper world. Can run a large range of diameter rotors and use 44mm and 40mm pistons
Price drop - $1800
Want $2050 for them. (was $2300) Have now purchased other brakes so ... :)
Can also supply radial mounts to whatever brand and diameter rotor you want to purchase and run
https://www.sau.com.au/forums/topic/176472-new-f50-brembo-calipers/
  • Replies 41
Posted Images
  • 3 weeks later...
Well it appears i need these for an upcoming rally so will be throwing them on the car with 340mm rotors. So if you are interested i will gappily part with the rotor, caliper and adaptor setup once my new brakes arrive...the calipers and rotors will be 1,000kms old so will be cheaper. So make an offer
But it wont be a common 17" wheel to gfit the 355mm rotor.
I just sold the 332x32 mm rotors, so if you are after rotors i can track down some. The best bet is to grab some CSC rotors locally and i can get the adaptor made up. With the Aus dollar now sucking against the US/Yen buying locally is probably cheapest.
I now have 3 set of wheels and 2 brembo setups...need to sell some of this gear as i have too much money tied up in stuff lying around trying to get a usable package for my GTSt :laugh:
sorry if this has been answered but would these bolt straight onto a r33/34 gtr 330mm rotor and hub without needing custom brackets? How much bigger are they compared to the 33 brembos in overall size (not the piston size but the outside caliper size)?
They physically are much larger making them far more rigid. They run exernal bridge line making the brake fluid run much cooler. Lastly they run larger pistons giving you more braking torque. Completely different animals. The GTR Brembos are not that different to the Sumitomo calipers on the R32 GTR, the F50 calipers are completely different
They dont need "custom" brackets, but they do need brackets that are sized depending the rotor you want to run. Some kits have them used on the std Nissan Brembo R33 GTR rotor which is 324mm. Though typically the F40 caliper is preferred for this application.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
