hey guys im stripping my r33 gtr due to a ride off
bonnet needs a respray due to deep scratchs no dents $300
wheels 18x10
only have 3 have a pic of the moat scratched up wheel $300
most interior bit nothing over $50
hicas ecu $50
front drive shafts $100
rear bar $50
center gauges $100
nismo muffler $100
rear tail lights $100
abs $100
door trims $80 left one has a tear
momo steering wheel with boss to suit rr33 gtr $80
will not post big items unless buyer organizes a courier to pick it up my front door
all parts are located in S/E suburbs of melbourne if u want a quick answer ring me on 0420581496
will trade for parts of intrest to suit BNR32
got more stuff laying round taking up space let me no what u need
https://www.sau.com.au/forums/topic/176478-stripping-r33-gtr/
  • Replies 138
• Wipers - $30
Is the paint faded or peeling? If not I will take it
• Rear wing (Black) - $150
genuine adjustable rear wing with the brake light? Undamaged? if so ill take it
• Gear stick boot and surround bracket - $30
Would you sell the rubber boot underneed the leather boot that protects dust from comming into the gearbox?
Edited by Blitz_R33
I am after the following parts:
• Chassis braces - $35
Does this include?
- the under floor brace at the "B" pillar that incorporates a bar that goes under the tail shaft
- the brace in the boot between the suspension towers that the strut brace bolts to
- the front lower arm brace
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
