  • 1 month later...
My clutch is not engaging until right at the floor, still drivable but you can feel it should have more to it.
I've bleed the slave cylinder as mentioned above but its still the same?
The Fluid dampener you spoke about, Can that be bleed as the same process of Open, Pedal down, Close and then pedal up?
I was told it was a heavy duty clutch but not sure on what kind exactly, i had a quick sus by moving the rubber from underneath and seen an extreme purple plate.
Is there anything else i should be looking out for?
  • 1 year later...
So i had a good read of this thread and came up with the solution.
After bleeding the master.
On the slave cylinder If the bleed nipple is not at the high point, it wont bleed the air out.
So i took mine off, with a bit of tape to stop the piston coming all the way out.
Then i held it with the bleed nipple at the high point, and opened the bleed, pushed the piston in, closed the bleed, let the piston out.
Repeat until all air is gone, keep an eye on the fluid level up top.
Rinse well and get all the brake fluid off.
Works! :banana:
The bleed nipple should always be at the high point. If it's not, it's in the wrong hole or you bought the cylinder out of the wrong end of China
Yeah right.
Thats what you get for buying a car from idiots. Bits put together wrong. So many....... Anyway, another one to fix.
Ill swap them around.
It's not such a bad thing. Of course bleeding is a pain in the arse but that's about it. Make sure before you swap it around, you check to make sure the banjo fitting has a machined surface to crush the copper washer against. I have seen some cylinders actually made incorrectly. In those cases, you will need to leave it as is.
  • 2 months later...
why not reverse bleed slave to master?
- empty reservoir
- push new oil from can from slave to master, then no bubble
i reckn this is better
You should try to avoid pushing air into the master cylinder. It is bad practice. There are places where the air can be trapped and you will have difficulty getting it out.
That's why you should always bleed the master cylinder on the bench before fitting a new one.
I'm unsure how you would feed fluid into the slave cylinder anyway. if you're just attaching a hose to the nippple and the hose sits in the bottle of new fluid, that won't always work either. It is quite easy for air to be drawn past the threads of the bleed nippple into the system.
This method may have worked for you though. I'm not saying it won't. I'm just saying it is less likely to work in all situations but moreso it can cause problems not easily diagnosed.
  • Like 1
  • 2 years later...
Did this today as I replaced my master and slave cylinders. I already have a braided line so I only needed to bleed master and slave. I was fairly anxious about getting this right and went back and forth bled both until I was satisfied. I found it was easier and I had more control bleeding the slave by myself by pushing in the fork as it allowed my to do it slower and therefore see exactly the condition of fluid coming out. I did have an issue with the pedal only half responding in its normal way when I thought I was done, so I just got under and re-bled it all until I actually got all the air out and the clutch responded as normal. Went for a test drive and everything works really well now, so am happy with getting this done.
Yeah also doing this today. Clutch pivot snapped and I've ended up with a new clutch etc. When the pivot point snapped, the slave rod bent out to the side and in order to get it back in I needed to drag the boot off of the end of the slave. Need to fill the entire thing with no pedal tone at all. Fun fun. -_-
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
