hey guys
before i bend my steering arm, i just wanted to know the best / easiest way to replace the boot
car is r33 s1gtst.
now i stole someones pics here:
i've removed the nut closest to the camera but the arm doesnt want to come off easily, and may not need to if there is a better way of getting to the boot
any tips?
cheers
https://www.sau.com.au/forums/topic/176498-steering-arm-boot/
Undo the lock nut (it's the bit that the bottom of the red oval goes through).
rotate the tie rod (see the flats on it about 30mm up from the lock nut?) until it unscrews from the tie rod end.
Slide the boot off.
done.
If you're removing the tie rod you need to remove the locking tab at the rack end before trying to unscrew it so that you can re use it rather than fu(k it.
If you want to remove the tie rod end from the steering arm, put the jack under the hub to take up any slack in the suspension then just get a reasonable size hammer and give the steering arm a couple of sharp hits on the side. tie rod end should fall out without damage to the thread.
  • 2 months later...
Hi guys,
I wonder if either of you can help.
I am changing the power steering boots on my R32 GTS4. To start from the start...
I have removed the steering rack from my tie rod end and have removed the steering boots from the tie rod.
On the steering rack end of the tie rod there is a ball housing which is then connected to the steering rod.
Between the ball housing and the steering rack there is a large washer with a rubber ring on the inside of it. It seems to be drifting on the stering rod between the ball joint and the steering rack.
Should this be drifting around or do I have a problem?
Thanks.
mine has had that bit floating around for years with no problem. I initially thought it was a seal, but if it was then i'd have dumped all my power steering fluid on the ground many times over by now. I wouldn't be too concerned, it's probably just a stop of some description to stop metal-metal contact wne the steering is at full lock
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
