hey guys
before i bend my steering arm, i just wanted to know the best / easiest way to replace the boot
car is r33 s1gtst.
now i stole someones pics here:
i've removed the nut closest to the camera but the arm doesnt want to come off easily, and may not need to if there is a better way of getting to the boot
any tips?
cheers
https://www.sau.com.au/forums/topic/176498-steering-arm-boot/
Undo the lock nut (it's the bit that the bottom of the red oval goes through).
rotate the tie rod (see the flats on it about 30mm up from the lock nut?) until it unscrews from the tie rod end.
Slide the boot off.
done.
If you're removing the tie rod you need to remove the locking tab at the rack end before trying to unscrew it so that you can re use it rather than fu(k it.
If you want to remove the tie rod end from the steering arm, put the jack under the hub to take up any slack in the suspension then just get a reasonable size hammer and give the steering arm a couple of sharp hits on the side. tie rod end should fall out without damage to the thread.
  • 2 months later...
Hi guys,
I wonder if either of you can help.
I am changing the power steering boots on my R32 GTS4. To start from the start...
I have removed the steering rack from my tie rod end and have removed the steering boots from the tie rod.
On the steering rack end of the tie rod there is a ball housing which is then connected to the steering rod.
Between the ball housing and the steering rack there is a large washer with a rubber ring on the inside of it. It seems to be drifting on the stering rod between the ball joint and the steering rack.
Should this be drifting around or do I have a problem?
Thanks.
mine has had that bit floating around for years with no problem. I initially thought it was a seal, but if it was then i'd have dumped all my power steering fluid on the ground many times over by now. I wouldn't be too concerned, it's probably just a stop of some description to stop metal-metal contact wne the steering is at full lock
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
