Fark.... that looks nice. Will be getting that or the Saber smoke one for $20 more. decisions decisions. Does the Apexi one come in PSI?
Hahah. Na dont think it comes in PSI.
This ones is a mechanical gauge, came with APEXi stand, almost brand new in perfect condition, I picked it up for $100!
Worth every cent :(
Thanks,
Abu
got my saber yesterday - loving the electrical style - no need to worry about crushing an air tube when going through the firewall :(
the 'smoke-ness' is not as great as i was expecting, but it still looks cool. if my gf doesn't have a whinge i'll install it tomorrow morning.
hooked up my saber on the weekend - piss easy to do (partly because I already fed my wires through the other week when i tried to hook up what i found out was a broken gauge...)
What i did have to do though was cut some pieces of the tubing supplied with the gauge and fit them over the stock air feed thingo on each side of the cut i made for my gauge's boost sensor, because my tee piece was too big to fit into it. I wanted to replace the whole tube with the stuff supplied with the guage, but the inside diameter was too big to fit tightly to the plenum :santa: ... that probably doesn't make a lot of sense, but i'll take some pics tomorrow.
anyhow, gauge is sweet, pretty much matches the stock one, but the extra increments make reading boost a lot more accurate! turns out i max out at about 5psi in 1st and 2nd then up to 8psi in 3rd 4th and 5th?? this is with a bleed type boost controller currently set just above it's minimum (still haven't got my intercooler yet and was waiting til i had a better boost gauge and fmic before i up it)
yep to me gauges are important. mainly because they need to be accurate, reliable and fast reacting but also they need to be aesthetically pleasing. My advice is save the extra money and buy nice gauges. Nothing make a car look worse than cheap gauges.
^^^ +1
Agree 100% - Accuracy, and they just happen to look shite hot :thumbsup: I'm Y generation and mech lines running into the cabin don't "impressin me much"
I've mentioned before, I have two mates with VDO gauges that have needed to be sent back due to massive inaccuracies. Their warranty support wasn't so crash hot either. I'm not going to bag them though, i guess statistically they both could have gotten two bad units, and they both could have spoken to a dude on his rag, and the courier could have lost the order
Edit: They were worth the months of saving and im completely biased :huh:
Edited by GeeTR
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
