I’ve replaced my HICAS with a lock bar and it’s been in there a while now, couldn’t be happier with it, but unfortunately my old man found HICAS unit and was instantly worried :laugh: .
Are there any legal issues with doing what I have done? Will it wipe my insurance? More importantly does anyone know if insurance assessors would look for something like this so vehicle specific?
Now I’ve I called around to a couple places and no one can seem to tell me what I need. My Dad seems to think I need an engineers report, but this seems a little excessive for something that essentially just making it the same as every other car on the road without HICAS. Would a mod plate cover this sought thing or is it deeper than that?
Cheers,
Brett.
i would be thinking that yes there would be a legal issue with them. say for example you was in a car accident that killed someone than your car may be examined and it could be found that because you had a un-tested lock bar it may have caused the accident. then you would be in the shit. like any mods thoe.
the chances of this senareo ever happening would be very slim but if you was conserned then just get a engerneer cert ant it should be all good.
hope that help and its only my oppinion so it has not legal bearing or anything like that.
i had a simmilar issue when i made myself a set of adjustable castor rods. i was told if they snapped and i had a bad accident then i would be at falt. but that goes for any mods you do.
Cheers, that's kind of confirmed my fears. An Engineers report costs lots I believe, so looks like I'll just have to put the standard equipment back in.
Unless the lock bar you have installed is made of tin foil, you really have nothing to worry about. It's not going to break, it's not going to be the cause of an accident.
It's a certainty that the lock bar hasn't been tested to conform to ADR's, so unless it's engineered it's not legal. But seriously, who's going to spot it?
If you are really that concerned then reinstall the stock rack and make up a couple of 5mm washers to fit on the end to lock it up that way. You end up with a 3kg or so weight penalty, looks stock once the boots are reinstalled, no hicas.
yes, it's definately illegal to remove a rear steering rack from a car that was fitted with it form factory. as for your insurance being voided by it that is a question for your insurance company.
Yeah true, but just cars are assholes. Even if my car is in an accident and I'm not at fault they'll probably still look for a way to screw me out of my money.
Really, it shouldnt cost you more than $120 you being in QLD. When I had my rb25 box put in, the standard mount was moved backwards. I had that engineered and mod plated, cost $120. I cant see a lock bar being too much different to that for an engineer to look at and plate.
I told just cars insurance about my lock bar, they just said "as long as you get it fitted professionally you'll be right." I just described it to them as a unit that removes the 4wheel steering and they understood. They didn't whack me any extra money for it either. As long as notify them of all the mods on your car, they'll insure you for them.
Cheers, never thought they would. Think I might do as dangerous_daveo said too and get it engineered and mod plated to be safe.
The fact is if you are not using genuine Nissan windscreen wiper rubbers then you car is "illegal". Non genuine brake pads, non genuine brake fluid even non genuine mud flaps........basically you can't use anything that isn't genuine Nissan. Think about it, you have "insert name here" brake pads, so you couldn't stop to avoid the accident, sorry no insurance. But they are "better" brake pads, so what, they are not genuine. Winscreeen wipers, accident in the rain, bad luck, no insurance........
Check you old man's car out and find every non genuine part on it and pick on him for a change.
:P cheers :nyaanyaa:
:laughing-smiley-014:
Good point SK I'll hassle him about his non-genuine heater tap he's about to put in his car. Yeah, so I ended up calling just cars and they accepted the lock bar, so it's staying in there. cbf getting a engineers report and mod plate now.
well this is the thing. there is a difference between a mod being illegal, and being unsafe (or unroadworthy).
as long as:
1. your insurer has been informed about the modification
2. they were installed/peformed by a professional or at least installed/carried out correctly and safely
3. they do not reduce the safe operation of the car
then you should be fine.
Sorry, but I don't agree with you on that one gary. Basically, there are Australian Standards (ADR). Your car has to comply with ADR.
Essentially, say for example,w hen you first bought your car, it would have had nissan brake pads. They would have been ADR compliant. When bendix make brake pads, they are ADR compliant, and therefore, they are legal.
Same as the window wipers, etc.
If you check the RTA's website, there is a fact sheet about suspension/chassis modifications.
But I do agree with you in regards the insurance and accident point :laugh:
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
