Hi and welcome to the forums. You should do a search of some sort before starting a thread. There's a thread below this one that could be of some help to you. Pretty much the same question. If you can't find it, it's this one:
http://www.skylinesaustralia.com/forums/in...howtopic=176489
Cheers
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3229488
Cheers
thanks Adam
cheers
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3229493
hey mate,
i was in your situation 6 months ago, it all depends on your goals and financial situation, my advice is do alot of research before buying anything, one thing ive found is that once you upgrade one thing you need to upgrade two more to support it, also unless you know alot about cars and engines its better to stick to things that have been tried and tested, if it works for everyone else it should work for you too
i personally started off with a fmic (front Mount Intercooler), fuel management system, boost controller, and fuel pump, cat back exhaust and pod filter. about $5000 installed and tuned
Edited by 33drifter
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3229523
hey mate,
Thanks Damo
thats sounds pretty good what you have suggested and will look into it
Im going to do the intercooler and exhaust first i think - did you chip the engine when you put your front mount in - also what sort of boost did you wind it up
thanks very much for your help damo
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3229572
justjap fmic kit - $350
turbo back exhaust also from justjap - $700ish (although id recommend getting the split dump pipe with this)
boost controller - $35 (turbotech bleeder)
mv automatics auto shift kit (gives you direct shifts on your auto, no more granny shifts) - $350
engine management system $250 2nd hand SAFC (air/fuel only), $700-800 emanage ultimate, $1.5k pfc + tune.
theres lots of auto info on here mate. do a search and a fair bit should pop up.
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3229639
[thanks very much = very helpful
cheers]
https://www.sau.com.au/forums/topic/176560-mods-for-r33/#findComment-3232704
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
