Hey ppl, due to a recent upgrade, have the following parts for sale.
Stock cefiro rb20det manual ecu, $50
rb20det afm $50
Split dump pipe modded to a screamer sold
Dark material front seats, good condition $50 teh pair!
2 way diff in housing (r200), 5 bolt half shafts, fresh oil, 4.1 gears, can test drive in car, good condition, $800
stock grill, the one with two slots $30
all prices less postage, located in wollongong, call or msg 0410466635
cheers
Edited by CEF33Y
https://www.sau.com.au/forums/topic/176561-ceffy-and-rb20-bits-2-way-diff/
  • 2 months later...
this is glen right? hey man the dump and screamer u sold to me you said it was $80 but here u got it up as $50...shouldnt i be getting some $30 change?
  • 3 weeks later...
That was before I had to re weld it man, the screamer section was a fair bit shorter, was a bit of stuffing around
  • 1 month later...
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
