Hello all,
I recently got myself an N/A 1999 Nissan Skyline r34 25GT 4-DOOR sedan Tiptronic transmission, completely stock. I'm fully new to skylines and know not much about cars lol, so wonderin if any of you's could help me out:
Question 1: Is it normal for the car to jerk when you change the transmission from say Reverse to Drive (like the car gets a push, feels like a jerk)
Question 2: My fuel guage is incredibly innacurate (after I fill up, it shows as "full" even after like 70kms!)
Question 3: Is it ok to use normal ULP, if not... what exactly would happen?
Hope someone can help!
P.S. i've attached some pix of it if you're interested
https://www.sau.com.au/forums/topic/176564-couple-of-questions/
nice, got a clean car there.
Q1/ ensure the car is completely stationary when you change gears; i.e. reverse out of driveway, ensure car is completely stationary, foot solidly on the brakes, shift slowly but smoothly into drive, release the brake and onto the accelerator. give that a go and let us know.
Q2/ 70kms is fine, normally it's accounting for the fuel in the pipe from the filler cap to the tank.
Q3/ i wouldn't recommend it as i believe the lowest octane rating in japan is 98ron. you will get increase of knock and possibly pinging (more prevalent on turbo cars) on an n/a you might get away with it. to give you an idea i had to fill my car with unleaded once, because that's all the petrol station had - and my safc2 read knocks up to 46, as soon as i found a servo with premium i put it in straight away and once empty, i filled it up again with premium and i get knocks in and around 15-25'ish, this is of course due to the fact that my car is tuned for premium unleaded fuel. if you wanted a car to run cheaply on fuel, you wouldn't have gotten a skyline in the first place.
hope that helps
lol thanks to all, and EUG about your solution to question 1, i actually do always change it while fully stationary and in fact it gives less jerk when the car is still slightly in motion. it sorta feels as if the car is readying itself to pwn some ass lol. and lol ok 98ron it is, what's with hillzy telling me differently!
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
