Hehe series 1.5 reprazent
I also agree that buying a car with little to no mods is best. Also if you're buying off a member of a forum see what kind of things they are posting, for example if it's stuff like "drifting my 33 at the track this weekend!" freaken avoid it!!
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3230299
but remember that a modded one 'normally' shows that it's been well looked after and serviced regularly. not always the case if you buy a stocker from someone who didn't realise oil needed topping up :)
But yea, agreed.
heavily used track/drift weapons are probably a good thing to not buy! plus if you buy a stocker you can keep all your stock parts so you can swap everything back when you get your visits to regency :P
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3230419
Try and find one thats already got a Exhaust, Pod filter, Front mount and possibly a Power FC! If you find one with those mods then you will save a solid 3-4k on doing those basic mods yourself! Spewing i was gonna be looking at off loading mine soon, BUT things have changed and looks like she's staying with me! Was gonna be asking for less than 18k also!!!
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3235224
with 18k you good get something decent from a dealer who dont specialize in imports / skylines etc. IE, redling, synergy. Go to a Dealer with one or 2 lines that they may have bought off an importing company, their prices will start from around 19kish, i got mine down to 15k, so worth a shot!
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3238340
take someone with u who knows skylines or who knows how to tell if the car is genuine ie do the engine and chassis numbers match, accident damage, has it been resprayed, wats it hiding?? has it been put together (welded) with two halfcuts ? just be real careful and ask all the questions I ended up buying mine from sydney cause all I found in adelaide waz dodgey......as they say buyer beware
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3258906
oh yeah I forgot to mention that there are heaps of R33's round at moment particularly in sydney which therefore flows on to adelaide...as there now getting older in japan , heaps more have hit aust than ever b4...so you can bargain harder and shop around if a dealer tells u there "hard to get" thats bs ...theres way more around now than when i bought mine in december
https://www.sau.com.au/forums/topic/176585-buyin-a-r33/#findComment-3258926
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
