Item:
Nissan Skyline Gts25t 1997 model type M
Gold Coast
Item Condition:
~130,000km, all log-booked, oil changed every 5,000km, rear disc rotors recently replaced.
Car has had major service and now has rego until 02/08.
Modifications:
Engine: RB25DET, stock turbo, stock boost being run, only ever boosted to 10psi.
Exhaust:3" straight through to twin 3" shooters (Yes, it is loud).
Suspension:JIC coilovers (not for the faint-hearted, these are stiff). Also have stock springs & struts to sell with car.
Wheels: AMG 17" on the front, 15" stock R33 rims on the rear (will sell with the full set of 17s, however 1 rim is quite rusted).
Apexi turbo timer
Apexi SAFC
HKS sequential BOV
Blitz pod filter
Blitz LM front mount intercooler
Exedy HD clutch
GFB Bleed Valve
Screamer pipe
Cusco 2-way LSD (very tight) - have stock LSD to sell with car.
Mongoose Alarm & Immobiliser.
Reason for Selling:
Have caught the modification bug, and was looking to make big HP & torque, so much so I was going to do a 2JZ-GTE conversion in my 33. However after numerous budgets and much research and speaking to a few voices of experience, decided there was no way it was going to be worth the money in the long run (despite the power it would make), so I have decided to sell/swap this for something that is already extensively modified.
Price and Payment Conditions:
Am looking for $15,990 negotiable at the moment (without RWC), or swaps. I think this is a reasonably fair price for 97 R33, however feel free to voice your opinion.
Am looking to get an S13/14/180sx/R32 with a big engine conversion such as an RB25DET/1JZ/2JZ for drifting/dragging. However am interested in a getting a full on drift pig now that I have a daily driver to use.
Extra Info: [/size]
Car obviously wouldn't pass a RWC but there are ways around this.
And before anyone says anything, yes the car has been drifted, and would like to think whoever buys it will continue to drift it as it slides very well. Will sell plates with car as there is not much use for them unless I get another 33.
Car has no accident history.
Have not had much attention from police, never been defected (touch wood), not having a big bad bodykit makes a difference.
Even though it is "just another R33", there are not many 33s going around that ride this low or sound like this, so it at least has that going for it.
Pictures:
Contact Details:
PM or post here.
Edited by riceracer
https://www.sau.com.au/forums/topic/176606-r33-series-2-gts25t/
  • 4 weeks later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
