hey guys i have a half cut minus box and computerand motor... from a r32 gtst
2 plastic guard liners 50$
gtst cluster blue face 100$
digital climate control one button missing, no wiring, 50$
bonnet cable 20$
bonnet lock 20$
bonnet hindges the pair 20$
air con lines 10$
rb20de radiator 50$
indicater stalk 30$
steering column 80$
steering column plastic surounds 20$
drivers kick pannel covers wires 20$
excelerater pedal 40$
brake booster 50$
windscrean wipers 40$ the pair
center dash concole joins to dash 30$
windscrean botol 20$
fuse cover with the air vent 30$
clutch fan 30$
also have a few other things just ask me... no air vents mite have them little eye vents...no center platics or cluster plastic surrounds.
have some suspensions bits..
all prices are neg.
pics on request
thanks
mitch
0401877252
[email protected]
on the gold coast
https://www.sau.com.au/forums/topic/176617-r32-parts-from-halftcut/
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
