I ran a 13.4 on a stock 33 with exhaust....thats pretty quick....what has a stock 350 run?
id like to think that over 400 metres the line would catch up....crossing the line at 103mph....
Mate, that is an awesome time for a 33 with nothing but exhaust.
What kind of rubber were you using?
You must have got off the line quicker than Kate Moss when there's a camera in the room :-)
A stockish 350Z would struggle to run mid 13's. Maybe on cheater slicks it could run a 14 flat or a high 13. Most of the car mags have an Australian delivered Z33 running 14.3-14.5. The US ones made a bit more power, so they dipped lower into the 14s.
I've G-Tech timed myself (on a private road, of course) at 13.8, but my car's got most of the pipework replaced as well as a few other bits and pieces. I think that, with a better driver and tyres that haven't been ruined by countless skidpan events, it might run a 13.5 but I doubt I personally will be achieving that in the near future.
It should. My trap speed with just a catback and completely f**ked RT215s was 100mph. So against a stocker you should reel a stock Z in.
You cant compare the maunfacture spec tho....i find that they are way off....you never really see them below 14 seconds...
I was surprised with the 300C it ran a 13.5 stock....thought that massive thing would be over 14.....or more surprising a jeep, not sure what it was, but it ran a 13.2, thats crazy speed...
  • 5 years later...
Sorry to necro this post I can't help but reply, I have a stock auto R33 GTST Sedan... Just beat a 350Z... They do have you from 0-100 but after that, wooshhh the R33 is off. This is from a rolling start though, 40km/hr, I hit 180km/hr and was half a car ahead and still gaining.
Tried telling my mate this.
He did not agree.
ive got 3inch straight through, pod , splitfires & installing boost controller and FMIC next friday and turning it up to 10psi.Running ku31's all round with pedders xa coils. So just basic mods... Mate has a stock 350 ready to race.
Guess I'l have to video it and we'll see..
You will destroy the 350Z, the last few 350's i raced at WSID were 1/10th slower than me. The only one that beat me was a newer model that out launched me and did a 14.2-14.3 sec pass with identical MPH to me. PS this is in a NON TURBO 300zx.
FYI the fastest "stock" 350z time, Stock as in right down to the tyre, was a 2007 car. Thats a HR motor.
13.150 @ 107.62mph
2.027 60ft.
something to think about...
http://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
13.150 @ 107.62mph
2.027 60ft.
http://my350z.com/fo...-ons-stock.html
There's a 10MPH variance between cars there, never seen a 350Z do anywhere near those times bog stock or trap that sort of mph.
Its all been verified as the site says. There is no argument to be had.
13.65 @103.5
Thats an ADM 2009 model. With a slip.
Not arguing, all i'm saying is i have never seen one go that quick or trap that speed. Just trying to figure out why there is 10MPH variance between bone standard cars. Only things i can think of are large altitude differences and the fact that a few of the US tracks aren't exactly "flat" (read: downhill).
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
