Hey guys
I'm about to be the pround owner of a 1993 r33 GTS-T. I took it for a test drive the other weekend with my dad, and found that when i was a a low RPM the car was pinging, it only happend once when i was taking a corner in 3rd and you could hear a really loud rattle i spoke to the owner who is a machanic and he told me that, thats a usual occurance with these cars when in a low rpm, and it is betta to shifgt down and stay in higher rpm range. But i spoke to a friend about the car and he told me it is very un-usual for a car to ping at low rpm speically if there is really no performce mods on the car (3.5 inch dunp to a high flow cat, with a 4inch cat back to a 5inch cannon, and a front mount intercooler)
So i was wondering if anyone can tell me if the problem is something that i should be worried about and, not get the car or like the machanic said something that happens with these cars.
Please help me out i really dont want to buy a mellon, and never hear the end of "we told you so" from my rents. lol
Best regards
Vlad
(sorry about any spelling mistakes)
https://www.sau.com.au/forums/topic/176655-r33-rattle-pinging-unsure/
Farrrrrrrrrrrrrrrrrrk man 3.5inch dump and a 4inch dump??? you sure the noise levels legal in your state???
i have a 3inch dump, 3.7inch catback and its f**kING loud. lol
i wouldnt think its pinging tho... when you say low rpm, how low? as in under 4000rpm? it could be ur plugs... cos rb's run rich when more boost is added.. maybe clean your coils and check for cracks?
when you heard the noise were you in third gear and was the engine revving under 2000rpm, mine makes a sort of rattling noise when doing this, im not sure why but i dont think its something to worry about
that was spot on, i was in therd taking the corner and it might of been 2,000 RPMS or under when the nosie started, then as soon as the revs got up it stoped.
So is it something that i should be worried about, or just something that happens with these cars?
to be honest
blow that car off n go get something else
im sure you can buy a decent car without worries and trust me MORE worries will come later on so look for something that you know works!
how much is he giving it for?
to be honest
he wants 16 for it, i took out a friend to see it to and he too said the engine sounds fine, but yeah im worried abou that rattle!
lol i got no idea, i was just wondering if it was the same thing mine does, i thought it might have something to do with mine having a nismo GMAX twin plate clutch and a short shifter, but generally if i know its going to be revving under 2000 in third ill change down to second (unless im feeling lazy)
it doesn't seem to affect the cars performance at all so im not really worried about it. hopefully someone else knows if its bad or not
Yeah 3rd in a corner is to high a gear if your going slow enough. You've probably just put a lot of load on the motor trying to move it at such low speeds under a certain amount of rpm. Don't worry about it the car is fine. If it was pinging at high rpm, then I'd be worried.
Thank you all very much for the advice, i have just put a down payment on the car so hopefully i should be getting it soon, and asking "what mods should i start to do to it" lol
once again thank you
best regards Vlad
its weird tho cause it only seems to do it in third, meh,
Not necessarily. It'll do it in other gears to given the chance. eg. Driving up a hill doing about 60kph and putting it in 5th gear will put the car under load and will make the same sound. It just so happens in his situation he's in 3rd gear going even slower, probably more like 20kph around a corner and revving under 2000rpm and trying to accelerate thus putting the car under load.
Edited by KeyMaker
Mine does the same... Anything low and the whole car sounds like it's about to fall apart. I found originally that the stock heatshielding on the stock exhaust was loose and making the problem much more obvious, so I removed it. Now the sound is only coming from around the front.
As soon as the revs are up a little more, whether you are booting it or just cruising up to speed) it goes away completely. I *DO* find though, that it happens MUCH more easily when cornering.
Every morning I pull out from my street in first, and shift to 2nd as i'm turning, or I just turn in 2nd if there are no cars and I don't need to stop... this makes the noise every time without fail. I think I need to keep it in first while cornering, with lots of go, and some opposite lock. =-/
I had a similar problem on my 32 that occured around the 2200 mark. I found that it was one of the heat-shield welds on my metal-cat cat converter had broken and was causing it to vibrate. However if you are suss on the car don't buy it. There are plenty of others for sale.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
