I wanna buy a gtr r33... help
I would look around the market before choosing a colour. The reason being is with 2nd hand cars you wont always get your choice of colour. Look around and see what takes your fancy. Normally what happens is you walk into a car yard and see a skyline and say THIS IS MY CAR!!
  • Replies 145
Originally posted by Devilish Angel
i like this person...
and isn't 4wd safer cause better controle too???
but the lights on the 34 look good..
argh..
dilemma!!!
No! They're not! All car's have a limit, and when you break the limit in a 4wd, it'll really let you know about it.. My old man's friend *had* a 4wd subaru liberty. Until he hit a guard rail one day and wrote the car off. He believed that his 4wd car would be safer.
It's not power that kills. It's how it delivers the power. RB25 produces it's power more linear and smothly compared to an RB26, which is pretty much all or nothing.
Also a GTR 4WD is not like a WRX 4WD. WRX's 4WD system make any driver look like a future rally star, where a GTR's 4WD seperates the men from mice.
Devilish Angel: Whats the fastest car you have been in ??
Personally i think Gt-t's, gtst's and GTS 25t's are more dangerous then GTR's espically in the wet.
Make sure this is a car you REALLY REALLY REALLY want because at your age thats alot of money which could used alot more productively.
Ok heres what you do.
As cost of car and insurance isnt the problem, buy your dream R33 GTR.
Now the only thing is the fact that other people think you will right yourself off because of the power. And it would seem you are starting to listen to this.
Simple solution is to get your hands on a Power Fc computer for your car. This allows you to tune the car for more hp. Only what you should do is before the inlet manifold place an orifice, with say a 25-30mm opening.
This will limit airflow and reduce hp, you can tune the ECU to allow for the drop in airflow. You will probably have as much hp as a V6 Commodore, and still have 4wd.
You can also but a butterfly valve in the exhaust that will choke up flow and drop off boost pressure, but this wouldnt be so nice for the turbos.
You still have to respect that any car that moves can be overdriven and crashed, so you still have to be just as careful.
Then as you gain experience and become comfortable with driving, you take out the orifice and re-tune the Power FC and, voila, back to stock hp. (actually more if tuned properly)
Hows that for an idea.
You could do that
or
You could secure a block of wood under the accelerator pedel so you can't floor it.
Devilish Angel: seeing as you have been in a evo6 so you probably know the performance of these cars and you think you can handle it both from a skill side of things and mentality.
Get your GTR and come cruising :(
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
