I wanna buy a gtr r33... help
I would look around the market before choosing a colour. The reason being is with 2nd hand cars you wont always get your choice of colour. Look around and see what takes your fancy. Normally what happens is you walk into a car yard and see a skyline and say THIS IS MY CAR!!
  • Replies 145
Originally posted by Devilish Angel
i like this person...
and isn't 4wd safer cause better controle too???
but the lights on the 34 look good..
argh..
dilemma!!!
No! They're not! All car's have a limit, and when you break the limit in a 4wd, it'll really let you know about it.. My old man's friend *had* a 4wd subaru liberty. Until he hit a guard rail one day and wrote the car off. He believed that his 4wd car would be safer.
It's not power that kills. It's how it delivers the power. RB25 produces it's power more linear and smothly compared to an RB26, which is pretty much all or nothing.
Also a GTR 4WD is not like a WRX 4WD. WRX's 4WD system make any driver look like a future rally star, where a GTR's 4WD seperates the men from mice.
Devilish Angel: Whats the fastest car you have been in ??
Personally i think Gt-t's, gtst's and GTS 25t's are more dangerous then GTR's espically in the wet.
Make sure this is a car you REALLY REALLY REALLY want because at your age thats alot of money which could used alot more productively.
Ok heres what you do.
As cost of car and insurance isnt the problem, buy your dream R33 GTR.
Now the only thing is the fact that other people think you will right yourself off because of the power. And it would seem you are starting to listen to this.
Simple solution is to get your hands on a Power Fc computer for your car. This allows you to tune the car for more hp. Only what you should do is before the inlet manifold place an orifice, with say a 25-30mm opening.
This will limit airflow and reduce hp, you can tune the ECU to allow for the drop in airflow. You will probably have as much hp as a V6 Commodore, and still have 4wd.
You can also but a butterfly valve in the exhaust that will choke up flow and drop off boost pressure, but this wouldnt be so nice for the turbos.
You still have to respect that any car that moves can be overdriven and crashed, so you still have to be just as careful.
Then as you gain experience and become comfortable with driving, you take out the orifice and re-tune the Power FC and, voila, back to stock hp. (actually more if tuned properly)
Hows that for an idea.
You could do that
or
You could secure a block of wood under the accelerator pedel so you can't floor it.
Devilish Angel: seeing as you have been in a evo6 so you probably know the performance of these cars and you think you can handle it both from a skill side of things and mentality.
Get your GTR and come cruising :(
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
