Basically the way it works is...
The intercooler cools the air that your turbo is sucking in before it goes into your engine. This means that, due to the lower temperature, the air is more compressed. There is therefore more air per unit volume. This means that more air is able to go into your engine and create a bigger bang making more power.
With a front mount, esspecially on RB's, you can get more lag due to the piping going all over the top of the engine. This means that the air needs to stay at that particular pressure for longer to get into the engine creating longer lag. If you shorten the piping with a different intake plenum. eg GReddy, lag will be reduced again as the air has less distance to travel.
Hope this helps.
P.S If I just confused you, or if anyone thinks I'm talking crap... feel free to explain further :D
https://www.sau.com.au/forums/topic/176777-intercooler/#findComment-3231909
  Dani Boi said:
I need an intercooler. Are those M-Spec ones on JustJap anygood? or should I just get one of those cooling pro ones?
PS. Im a tight arse >_<
Im guessing they would be alright, i dont know anyone with one but still would be ok i guess, unless someone has had problems with them and wants to correct me.
Im currently using a monza 300 x 600 x 75 cooler and for a cheaper brand its very good and the quality isnt too bad either, im happy with it. :D
https://www.sau.com.au/forums/topic/176777-intercooler/#findComment-3231957
just buy a greddy m-spec kit, cost is around $600-$700 depending where you get it from.
they may be a about $200 more pricey than the china kits, but the quality of the pipe work is excellent and you know it will bolt in no problems. also the greddy endtanks are better than the china coolers endtanks
just my 2cents
https://www.sau.com.au/forums/topic/176777-intercooler/#findComment-3231984
if your keeping car relativly stock i wouldnt worry about putting one on.. you wont notice any power increases if thats the only mod your planing to do..
but i would chuck one on if you wanna chuck some more boost into etc etc
also Fmic look awsome
ps pay someone to do it.. its not as easy as everyone says it is to put on
https://www.sau.com.au/forums/topic/176777-intercooler/#findComment-3232151
Alright thanks for that info. I really just like the look of intercoolers dont think I'm planning on doing major engine modifications I mean im only 18 and want to live lol :) plus im getting 400R front so thought I may as well get it together.
Cheers, sorry for hijacking thread lol
https://www.sau.com.au/forums/topic/176777-intercooler/#findComment-3232998
