Hey guys,
just wondering if any knows anything about the fuel warning light. My light doesn't come on when i'm low on petrol. checked the globe and thats fine and the fuel gauge is working. anyone had this problem? and can someone lead me in the right direction to fixing this.
https://www.sau.com.au/forums/topic/176835-fuel-warning-light/
Light only comes on when you have less than 10L left, mine came on for the first time last week. What lead you to believe the fuel warning light was faulty? Did you run the car to empty with no warning or is it just the gauge, if its the gauge don't be alarmed, pretty much everyone on here with 33s has the same problem and from what i can remember its from a dodgy fuel sender which has more than likely fallen off its perch inside the fuel tank, this is why you get weird readings (mine never reads more then 3/4 full even when i fill it up and will sit there for about 200km then work its way to empty).
If you did run it empty... well then your in for all sorts of fun with that :P Otherwise just fill it up and reset the trip meter, drive it for about 300km and fill it up again, note how much you have to fill it up to get to a full tank again (full r33 tank is around 65L) so say you did 300km and used 40L well next time drive till 350km and see how much to fill up a full tank, repeat until you are left with 10L at refill (leeway for occasional hoon behavior :D) and just remember to reset the trip meter every refill and drive till that set kms (I fill up and drive 350km before heading to the local BP)
Or if you want to be gung ho and not a lazy sod, you can pay someone to fix it and not worry about any of the stuffing around remembering numbers
my fuel light has only ever come on once. and that was only because i wanted it to, because i was asking myself the same question as yourself, David.
My fuel gauge was actually sitting on empty, and after driving around 100km whilst sitting on empty, the light decides to come on....
So, quite a similar situation to what Baconer has explained.
every time my fuel gauge would hit the empty mark, i would go and fill it; and i would only be able to fill around 40 litres!
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
