  • Replies 91
Thanks to all that placed there pictures into the comp Jason has chosen the Winners and lets just say that I think all winners will be happy!
I cant give to much away but I just want to say thanks to one and all !
  • 4 weeks later...
Well i think it should be in Next months issue so I will get back and let you know.
Also I have spoken to Jason from Hpi and Iain from Autosalon Magazine and I will Pm people with extra information as I might use you for further stories.
Interest is welcome if I have not seen your work.
  • 1 month later...
Well Good news to all the issues is coming out soon Ill grab the issue number in the next few days for you all. It should be good! So sorry for this taking so long!
HAPPY NEW YEAR >_<
  • 4 weeks later...
This is the pic, by far not my best... the car isnt even clean, its wet, and my old busted wing is still on there!
and the pic done to the advice given in the mag... (take out the tree and highlight the badge on the back)
  Granthem said:
yours made it in n15m0!!!!! cool shot too you do a similar picture as i aim for :banana:
farkn >_< I went around a few newsagents and all I could find was issue 88 so I bought it and its not in there!
Can someone scan and post it up???
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
