Need A Workshop In Dandenong To Do A Pre-purchase Inspection
Hey guys,
I've found a R33 GTR Skyline that I'm interested in and would like some recommendations of workshops in Dandenong that I can get to do a pre-purchase inspection, including compression/leak down and all the other usual stuff.
The seller works in Dandenong and can't get to racepace (which i've used before) during working hours cos it's too far...
I've got a recommendation from a friend about G & D performance, but they seem to specialise in Ford/Holden. Anyone dealt with them before for their skyline?
Thanks, much appreciated.
if you're serious, get it flat bed towed to RacePace and flat bed towed back.
Wow! that's pretty cool, hadn't thought of that! Really sounds like racepace is the best when it comes to this doesn't it?
Sure beats RACV going out, that's for sure :)
Well then, my next question is if anyone knows of a good towing company that has decent rates to tow about 20km there and 20km back at the end of the day. Better yet, does anyone work for a towing company? :)
Thanks!!
Well then, my next question is if anyone knows of a good towing company that has decent rates to tow about 20km there and 20km back at the end of the day. Better yet, does anyone work for a towing company? :(
Thanks!!
CITYWIDE TOWING..... :)
0419877437......Jack..
Jack is a SAUvic member and GTR owner.
Tell him your from the forums...
Awesome! Thanks heaps! I'll call them today.
I don't think RACV do compression tests on a car, even if you get a "comprehensive" check done. On their site, they say that they don't dismantle anything to examine internal parts; they only do visual checks. If you take the car to one of their workshops they put it on a hoist and examine the underbody and take of wheels to check rotor thickness, but that's pretty much the extent of it.
Have you checked that racepace will do pre-inspection test?
When i was looking for pre-inspection for my car, they told me they were trying to move away from that service, but they still did pre-inspection for me :whistling:
RACV do compression checks. They did on my car before i bought it. still, id take it to a good mechanic that knows his stuff. Ray at R E Customs in Springvale is good. he is my mechanic. then you could take it to Ben at racepace seams you know him already. thats if u can afford a tow. and for a tow, yea talk to Jack he's the man for tows!
Yeah, ran out of time to call Jack regarding the towing, but racepace told me the same thing... they're moving away from pre-purchase inspections because too many people would make appointments and then not show up, but they did one for me anyway (for another gtr i was interested in a few weeks back).
I'd be more than happy to pay 50% upfront or whatever though and the rest on completion, but they always do sound very busy. It sounds like Ben is a one-man show? Anyway, they do a brilliant job. I'll see how I go tomorrow, I'll make a few calls :whistling:
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
