NEED TO SELL AS I JUST BOUGHT ANOTHER CAR!!! 12,500 ONO...make an offer i will consider it!!!
12 MONTHS REGO!!!
Factory
*1989 NISSAN SKYLINE HR32 GTS-T M-Spec
*113,000kms
*Black
*Manual
Interior
*Rhino 3 Point immobliser Alarm system
*EL2 Apexi boost gauge
*Turbo Timer
Exterior
**In excellent condition**
**Previously belonged in the Autostyle garage.**
**White r32 gtst wheels
**Front sports lower lip
Engine
*Highflowed R33 turbo built by GCG
*Hybrid Front Mount intercooler with Custom Piping
*3-inch Full exforce exhaust system
*Fuel Cut defender
*Oil catch Can
*Turbosmart Dual stage boost controller
*Compression Test showed 145,146,145,147,145,146 PSI over the 6 cylinders (VERY GOOD SIGN!!)
Drivetrain
*Twin plate brass button clutch
*Brand New tyres
*All new front end suspension bushes
Extras
*2 spare tyres with 70% tread
*aftermarket BOV
*spare actuator off turbo
*spare dash and stereo/air con surround (in red)
*A set of original Mspec skirts and pods in this same colour as the car that are in my garage in great condition that im willing to throw in.
Car made:
*210kw@the wheels on 15psi
This car is meant for Skyline Enthusiasts who appreciate smooth efficient and safe power with reliability!!
Contact:
Or email me on: [email protected]
Located in Hurstville
Rego Expires 6/JUL/08
Had no troubles insuring with JustCar
Asking Price : $12,500 ONO MAKE AN OFFER.....I WILL CONSIDER IT AS I HAVE JUST BOUGHT A NEW CAR TODAY!!!
Edited by RB20JT
looks really neat!
i wish i had that money! i already am in $24000 debt and have 3 cars in the driveway.....
if i had the dosh mate i would fly up tonight and get it!
i can scrounge up $9000, but thats near enough to insulting you....
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
