1996 R33 Series Ii Gts-t T3/t4 High Flow Turbo, Forged Pistons 2.5 6 Cyl Turbo 5 Speed Manual. Black. 88,985km.
1996 R33 Series IIGTS-t T3/T4 High flow turbo, Forged pistons 2.5 6 cyl Turbo 5 Speed Manual. Black. 88,985km.
$19000
this car has to go getting out only a couple of times a week!. I have had this car for just over a year now and have had no trouble what so ever with it. it has been regularly serviced, and used top grade MOTUL oil. (last service was last month) Serious Buyers Only the specs are to follow: T3/T4 High flow ball bearing turbo (peaks at 18psi and drops off to 15psi over the rev range as programed) Full 4 inch Trust exhaust, Forged Pistons, Shaved heads, Greddy front mounted inter cooler Greddy Blow off valve, Lowered, Apexi Power FC full computer (with out controller) 18 inch BSA rims (245 tires) Slotted rotors in front breaks Boost Gauge ( good to 20 psi ) Blue 100w headlights Pioneer Head unit, Pioneer 6x9's and Pioneer Splits with amp in boot, Alarm and Immobiliser, will travel for genuine veiwers I am the second owner in Australia For more details please feel free to give me a call!
its been dyno'd and only running 217 rwkw BUT that is due to having stock injectors, with the current set up once stock injectors are in and a re-tune you will get some serious figures.
call me on 0402926106
im in tasmania (launceston)
but will sell to melbourne and bring it to them for the right price!
for pictures please pm me and ill send them to you!
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
