I have a problem with my driver side window. It is stuck in half way when I tried to close the window. My problem is very similar to this one:
http://www.skylinesaustralia.com/forums/in...howtopic=170188
Now I've taken off the trim and testing with the switch. So far it seems working as I see no losen solder joint and there is a tick sound with I press the button. But when attempting to check the window regulator, I found it is too complicated to remove and fear the glass may fall out if I unscrew the motor. Has anyone a suggestion how I can take the motor out for test/fix?
https://www.sau.com.au/forums/topic/176889-driver-side-window-regulator/
Ă—
Ă—
