Hi all
Ive been suffering from a LOUD screeching squeal on occasion with light braking, sometimes even heavy.
I run standard rotors and Formula Ferodo pads (TS2000). It only really started when I put these pads in and guys at Midas couldnt figure out what it was. I left them as it is because my poor pedal feel was more of an issue that the squeal.
However after a track day, and trust me I didnt push that hard on the track, the screech was just as loud, but this time, almost every brake application caused it. This became very frustrating.
After researching for a while this is the process I came up with the fix the problem. Had some spare time so my mate helped me do it.
Basically:
1) removed the pads and shims
2) cleaned shims, back of pads and rotors with a spray on brake cleaner
3) cleaned the slit in the middle of the pads (they had massive dust build up in there)
4) sanded the pads down a little to remove any glazing (couldnt tell if there was any, not sure what it looks like haha)
5) chamfered pads with a file (ie. filed down the leading and trailing edge of the pad so its angled)
6) put some CRC brake squeal quite red goo in between the the shim stack and the back of pad
So its shim stack --> GOO --> back of pad, i didnt end up putting the goo in between the 2 or 3 piece shims
Straight away no sound, 2 weeks later, no sound!
Hope this helps.
  • Replies 68
Posted Images
  nuffsaid said:
Hi all
Basically:
Hope this helps.
Interestingly enough, i have the same pads, and i did EXACTLY as you did! Even filed the edges, used the same CRC goo, and the sound didnt stop :w00t:
Im taking the pads back and getting a replacement. Might buy a new shim kit as looking at the image on the previous page i am missing one of them. *sigh*
So ill start fresh, fresh pads, fresh shims, fresh skimmed rotors, and fresh goo.. will update when i have done it. As it driving me CRAZY!
Edited by gotRICE?
  Cubes said:
That shim kit is identical to what mine uses.
You need to goo. Use it. If your mechanic won't find another.
Fair enough... but he's never steered me wrong before, and you should HEAR what he says about mechanics that smear brake goo on the back of pads! =-o (my word!)
I might persist with it a bit longer and look into those shims. I know I have the four little corner ones, and the solid faced bits... but I don't recall seeing the vented ones. =-/
I'd just thought id share my experience now
Seeing as i had a set of Ferodo Formula TS2000's that squealed like a 12 year old getting ***** up the ass by a cat on a chalkboard, i tried re skimming the disc's, brake goo from Nam still to no avail.
So, i returned my pads to Repco (handy having a mate there) to swap for another set the same.
Just out of curiosity we checked the pads, the old squeaky ones next to the new ones, apparently the same.
The old ones were a bare pad, in green
The new ones were a black pad, with a green rubber piece over the back, where the squeak shimms would go! Interesting!
So, getting home, installing the new pads, and just re-using the squeak shields covered in CRC Squeak stop (NB i did NOT apply any more, as there was still a sufficient coating, and did NOT apply any to the pad surface itself)
Cleaned everything again with brake cleaner, re-installed everything, bed them is as per instruictuons. Let them cool off completely, and i have just been for a 5-10min drive around the city, up hills, down hills etc with variable brake force, and im happy to report that the brakes havnt uttered a peep :cool:
Hope it stays this way!
GL for everyone else. As it seems, there is no guaranteed cure. Its just trial and error, and i have found my correct method :wub::(:) All smiles here!
Just thought id add that after a few hours of driving around town, the squeak came back :) but it is intermittent (spelling?) and is nowhere near as loud as it was, so its bearable.
Hoping it might go away with age and wear.
I was about to suggest that the noise would come back. It did after I got my car back... a few days and the rears started... then a few weeks and the fronts are going mental!
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
