I got an 1990 r32 gtr, was wandering if it was possible to know what engine my car was from..side of the block says 24U..so i assume its an N1 motor.r32?r33?.r34?
..and one thing that has me stumped is looking at the engine number ,in between RB26 and serial number there is a little R stamped. Everyone i spoke to has never seen it or heard of it... looks like this :
RB26
--------------R
060643A
without the slashes..
I also took the rocker cover off and noticed that the head bolt has a little dot on the rim of the hexbolt..all the ones ive seen are smooth.
thanks guys.
https://www.sau.com.au/forums/topic/176895-n1-block-with-a-r/
dude! that would have to be one of the bluriest pictures I've ever looked at!
I'm pretty sure the R is on all N1 blocks. the GT blocks have RRR. Though someone with more block knowledge that me can confirm it.
sorry about the photo, camera was really crap and too close to focus. il get some better photos up.
Ive looked at 5 n1 blocks, but they dont have a serial number on block. Was told if you order a block new from nissan,it has no serial number and the ones i looked at has no "R". So i assume its a factory N1 engine but out of what??32,33,34?
Is there a way to tell with the serial number?
thanks.
have you nissfast the number it may give a little more insight?
i didnt know you could check engine numers with fast..hmm..i could post the vin ad model number but im pretty sure the motor is not the original. This car is a bit funny, had a factory exhaust on ( brand new). high pressure intercooler hose clamps, huge alloy radiator with built in oil cooler,front subframe is all drilled out ,high boost setting on the hks evc was at 1.5bar?!? and when the car arrived from japan the clutch was completely destroyed..nismo twin plate. So it just raises suspicions to what it had in japan or what the capabilities of this motor is.
somebody must of seen this " R" before..no one in nz has... = ( , and not one reply from the gtroc forum. Its one of those things that annoy you until you can find the answer...= ).
SOUNDS PRETTY COOL. but its just a block. if your not making over 700hp it really doesnt matte.
being 06...... engine number id say its a 33. a early one.
Finally were getting somewhere..thank you! So an r33 motor.. Spoke to someone today and he told me hes only ever seen that head bolt on r34 motors...so hmm..
I got a street r32 that i ve done evrything to , except motor wise, so was thinking if this motor was up to spec, might swap it over..
700 hp at crank is the goal running 2530's. more than enough for me for the street. Trying to save money where i can for my drag car.should run this season. That car runs twin 3540's ,motec 800,adl pretty much everything under the sun. 1200hp and mid to low 8 is the goal..should post some pictures..not blurry ones..haha. = )
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
