Hi all,
I have a problem with black soot on my rear bar. It has always had a bit on the back, car is white, but has gotten worse since buying the car 6000km ago. I wash it take it for a 20min drive and it is covered again.
I have had the AFR checked and they were supposedly spot on. The cat still seems to be working properly as it doesnt smell like raw fuel.
What else could be causing this? It seems to do it worst when I take 2nd gear to the redline, I can visibly see the smoke out the back.
Car is:
96 33GTS-t
FMIC
PFC
Split dump to 3 1/2 after cat
HKS Pod
Bleed valve at 12psi
Any suggestions would be appreciated, thanks.
Edited by smoothR33
https://www.sau.com.au/forums/topic/176910-black-smoke-on-boost/
Has to be the tune, or a leaking injector or two or a dodgy fuel pressure reg.
anyway your AFR must be way out to be seeing black smoke out the back of your car while moving. How do you know that the AFR as ok?
Edited by tacker
you may possibly have a gutted cat, i no that this is common when the insides of the cat are bashed out....could maybe just need a tune as others have said
+1
my mate has (we are pretty sure) a gutted cat or callapsed cat and his car is filthy on the rear. his afr's are 12.0:1
I've been behind a stock 32 GT-R and a modded 33 GT-R (PFC), and they both exude a lovely black cloud when "nailed".
Stop running to red-line in second, and you might at least reduce the problem!
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
